Loose Steering play in the steering Box Gen1 Raider #1049686 08/04/12 10:00 PM
RaiderMonteroFL Offline OP
Appears all of the play is in the box. The Steering column and shaft are good from what I can tell and the pitman arm and other lower components are tight. Is this fixable or replacement? Searched and found a few threads, but not much detail as to what has to be done to fix it.
Still drivable but I kinda feel like the dukes of hazard driving down the road with the wheel going side to side. javascript:void(0)
Re: Loose Steering play in the steering Box Gen1 Raider [Re: RaiderMonteroFL] #1049687 08/05/12 01:19 AM
There's an adjustment screw on the top of the box. Set the steering wheel straight ahead. Loosen the lock nut and tighten the screw with a large flat blade screwdriver. If you get it too tight, the steering won't self center from a turn, so go easy. I twiddle the lower shaft as I tighten to feel the slack disappear...
Re: Loose Steering play in the steering Box Gen1 Raider [Re: fasteddy] #1049688 08/05/12 12:29 PM
METALMOVER Offline
Hmmm I have a little slack in mine also, I believe I will try that today.... I will have to learn how to twiddle though.... Thanks Eddy METALMOVER
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
Re: Loose Steering play in the steering Box Gen1 Raider [Re: fasteddy] #1049689 08/05/12 04:56 PM
Here is a pic of the box. Where is the adjustment screw?
Re: Loose Steering play in the steering Box Gen1 Raider [Re: RaiderMonteroFL] #1049690 08/05/12 06:17 PM
HTH
Re: Loose Steering play in the steering Box Gen1 Raider [Re: rxinhed] #1049691 08/05/12 06:20 PM
LandRaider Offline
Yeah... Like Rus Says... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Loose Steering play in the steering Box Gen1 Raider [Re: LandRaider] #1049692 08/05/12 07:15 PM
That was it. I could not see the screw slot for all the grime that was in it. Unfortunately it appears that adjustment was already tweaked to it's MAX. I tried to tighten it some more to no avail. So the play is still there with no change.
My guess is the spline or receiver gear coming from the steering column have just worn to the point there will be significant play in the steering. Dang it Mitsubishi this truck only has 183K miles on it and stuff is already wearing out on it.
Re: Loose Steering play in the steering Box Gen1 Raider [Re: RaiderMonteroFL] #1049693 08/05/12 07:56 PM
hochkis Offline
You did loosen the jam nut before trying to tighten it right? Mine was so grimed up I did not notice the jam nut.
95 Montero SR- Stock
90 Turbo Miata - TD04 wrx turbo, Flyin miata suspension, Torsen diff, 225 RS3's
92 Mighty Max 4x4 - Retired
Re: Loose Steering play in the steering Box Gen1 Raider [Re: RaiderMonteroFL] #1049694 08/05/12 08:00 PM
BottomFeeder Offline
There should be room to "twidle" still. Hard to believe it would be maxed out already. Mine was very hard to turn the 1st time I had to adjust it. I had to use long ratchet attached to a flat bit and a long extension to break mine free. It finally broke loose. Seems like I sprayed half a can of wd40 on it too.
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's.
1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
Re: Loose Steering play in the steering Box Gen1 Raider [Re: RaiderMonteroFL] #1049695 08/05/12 08:27 PM
geocrasher Offline
Wearing out at 180k miles? I doubt it ;-) (see my sig)
http://tidbitsfortechs.com/
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6396 MB (Peak: 0.7638 MB) Data Comp: Off Server Time: 2026-05-29 19:57:38 UTC
