Anyone have a line on a decent deal for Mitsu ATF for my 96? #1049809 08/09/12 11:30 PM
off-roader Offline OP
Will be doing the tranny flush and decided to treat it out a bit and go with either Mitsu or Hyundai (compatible right) fluid. Anyone have a line on a good priced source?
Re: Anyone have a line on a decent deal for Mitsu ATF for my 96? [Re: off-roader] #1049810 08/10/12 03:20 PM
WigWiggy Offline
I looked all over the internets when I did mine and concluded that my local dealer actually had the best price. Think I got a case for around $65.
Next best thing I could find was here on ebay
98 Montero, 184k.
Re: Anyone have a line on a decent deal for Mitsu ATF for my 96? [Re: WigWiggy] #1049811 08/10/12 05:14 PM
Grasscat Offline
My owners manual and shop manual says to use ATF DEXTRON II or equivalent, 10.4 qts.
Someone needs to show me/us where it says to use only Mitsubishi ATF.
I've heard all the stories over the years, but show me the facts.
Here's something to chew on.
Dexron Mercon III supercedes all previous Dexron II specifications. You can safely use it. You can also use Dexron IV, which is even better and compatible with Dexron III and II specifications.
Did you know that the original Dexron had a high percentage of whale oil, Dexron II was formulated without it. Original Dexron is arguably the best tranny fluid ever created, but due to its ingredients cannot be made anymore.
OK I've got my flame suit on so fire away. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael j
TreadLightly! Trainer
Re: Anyone have a line on a decent deal for Mitsu ATF for my 96? [Re: off-roader] #1049812 08/10/12 07:06 PM
P
pcc Offline
July purchase of 12 qts at dealer was $6.75/qt. + tx. = $86.47
Re: Anyone have a line on a decent deal for Mitsu ATF for my 96? [Re: pcc] #1049813 08/11/12 04:58 AM
Angelo Offline
I'll have to check with my Mitsubishi guy. He usually gives it to me at cost. I could find out
Re: Anyone have a line on a decent deal for Mitsu ATF for my 96? [Re: Angelo] #1049814 08/11/12 09:37 AM
Monster Offline
I had a to install new filter and oil pan gasket and my mechanic used Dexron 4, seems to be running good, except that when cold it revs up a bit higher till it changes gear.
Re: Anyone have a line on a decent deal for Mitsu ATF for my 96? [Re: Monster] #1049815 08/11/12 05:05 PM
Grasscat Offline
In what kind of vehicle?
Michael j
Re: Anyone have a line on a decent deal for Mitsu ATF for my 96? [Re: Grasscat] #1049816 08/11/12 06:54 PM
Be careful with some of those dexrons as you won't have a working transmission anymore. I know i know the whole "i've used it for years with no problems" and "this friction modifier makes it SP equivalent".
Just remember that these are Japanese trucks with Japanese parts and Japanese manuals translated into English. I've found more than one serious mistake in the manuals, My favorite is the 90ftlb of torque on injector assembly I tried it and it didn't work and i have the broken injector as a reminder.
I think there are a few other threads on this subject, even a mobile 1 vs Diamond SP thread. Ray i heard a rumor that you can get Diamond SP at a discounted price at the Hyundai dealer stickered as Hyundai SP or something. I personally just have the dealer do my trans flush as it is cheaper than DIYing it because they have the machine to do it.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6228 MB (Peak: 0.7210 MB) Data Comp: Off Server Time: 2026-07-16 16:10:35 UTC
