Balance shaft belt jumping time (slipping) #1049877 08/12/12 03:37 AM
rollguy Offline OP
I had a major front crankshaft seal leak, and that caused the balance shaft belt to come off. The belt was ruined, so I got another one. Today I installed the belt, and just for grins, I left off the covers, fan and radiator, and started it to make sure there was no leaks (yes I installed the crank pulley!). I started the engine, and revved it up from under the hood. When the engine got to about 2,500 RPM, I heard a weird sound and noticed that the balance shaft belt vibrated at the same time. I revved it up again, and the same sound and visual vibration. I turned off the engine and put it back on TDC. I noticed that both balance shaft gears were not lined up with the marks. I can only assume that the sound I was hearing was the belt slipping on the gears. Has anyone experienced this before? Does anyone know what would cause this? Just for fun, I changed out the tensioner with a known good one, and timed up the belt and fired it up again. Same thing happened again. HELP!!!!
All Diesel Fleet:
1985 Mitsubishi 2.3 Turbodiesel Pick-up, 1983 GMC Van- 6.2 Diesel.
Benzs: 1995 E300 diesel, 1980 300SD, 1982 300CD, 1983 300D, 1985 190D.
1980 AMC Eagle Limited Wagon powered by: 3.6 Litre I6 VM Turbo Diesel Engine (one of fewer than 10 made, only 2 known to still exist)
Re: Balance shaft belt jumping time (slipping) [Re: rollguy] #1049878 08/13/12 02:47 AM
rollguy Offline OP
Here is a video of the belt slipping. You can barely hear it, but you can definitely see the belt vibrating when it is slipping.
http://s84.photobucket.com/albums/k13/rollguy/?action=view&current=IMG_1112.mp4
Any ideas?
All Diesel Fleet:
Re: Balance shaft belt jumping time (slipping) [Re: rollguy] #1049879 08/16/12 04:31 AM
rollguy Offline OP
I found the problem today. The lower silent shaft rear bearing is shot:
I think I figured out why. When I had the engine rebuilt, I cleaned all the parts that the rebuilder did not get. The 2 front covers were some of the parts I cleaned. When I put together the counter-rotating gears, I must have not timed them correctly. I compared the shaft to the timing gear with a spare front lower cover, and the two shafts are not in the same spot. That probably caused so much vibration, that it took out the silent shaft rear bearing. I may have to pull the engine again, bummer....
All Diesel Fleet:
Re: Balance shaft belt jumping time (slipping) [Re: rollguy] #1049880 08/22/12 04:40 AM
rollguy Offline OP
I got it fixed and running!!!
I made a bearing puller/installer and harvested a bearing from a spare block I had:
I pulled the bearing into place with the puller I made:
Bearing in place:
I replaced the silent shaft with a spare one I had. Here is the damaged one:
I got the engine started, and it runs great!
All Diesel Fleet:
Re: Balance shaft belt jumping time (slipping) [Re: rollguy] #1049881 08/22/12 07:53 AM
LandRaider Offline
Congrats on the fix. Im terrified to open mine up. It's all magic in there. Unicorn horns, and fairy dust!
Re: Balance shaft belt jumping time (slipping) [Re: LandRaider] #1049882 08/22/12 04:16 PM
rollguy Offline OP
You have one with the same problem? Nothing to worry about, it's not as hard as you may think. No magic involved, or fairy dust needed. I originally thought I would have to pull the engine (again) and take it all apart in order to get a new bearing installed. I did not know if it needed to be machined (if so, the entire engine would need to be disassembled), but I thought I would try installing a used bearing first. I am blessed in that it worked, and it was not as hard of a job as I thought it was going to be!
All Diesel Fleet:
Re: Balance shaft belt jumping time (slipping) [Re: rollguy] #1049883 08/22/12 07:08 PM
LandRaider Offline
Nono... Mine runs perfectly... Thats why I'm afraid to even look inside there!
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6236 MB (Peak: 0.7168 MB) Data Comp: Off Server Time: 2026-06-10 07:28:08 UTC
