NOOB question.....1990 4Runner #1050059 08/17/12 03:19 PM
Staceman Offline OP
OK, I am now the proud temporary owner of a 1990 4Runner. I'm going through it before my step-son gets it. The front side marker lights do not work. No biggie. How the heck does one remove the marker light to check the bulb? I removed the 2 screws attached to the rear of said marker light assembly, and was hoping that sliding it forward would release it. No go. No owners manual. Suggestions? Thanks!
Re: NOOB question.....1990 4Runner [Re: Staceman] #1050060 08/20/12 01:34 AM
kewlynx Offline
Pop open the hood and see if you have a screw that goes in from the top. It would be right there in the front corner. My 3rd gen is like that.
I don't think the front markers have a bayonet pin that would make popping it off difficult.
You might have to get a common SD between the trailing edge of the light assembly and the fender, and give it a couple good whacks to pop it loose.
**ubi apis- ibi salus**
Re: NOOB question.....1990 4Runner [Re: kewlynx] #1050061 08/20/12 10:14 PM
Staceman Offline OP
Found it.. After looking at pics of replacement parts online, I just needed to pry harder between the grill by the headlight, and the marker lamp housing, than I was. There are 2 pegs the pop into place on the grill. Lights fixed BTW. Thanks!
Re: NOOB question.....1990 4Runner [Re: Staceman] #1050062 08/21/12 01:42 AM
kewlynx Offline
Cool. The roomie's Corolla brake light assemblies have pins on them that are about 2" long. It's a bear to get 'em off, but they'll come off. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6011 MB (Peak: 0.6571 MB) Data Comp: Off Server Time: 2026-11-03 13:38:46 UTC
