OEM AC Receiver Drier does not fit on my GEN1
#1050319
08/25/12 12:17 PM
Anyone else run into an issue where your AC system does not seem to be stock?
Mine has a different compressor, drier and bigger hoses. I am thinking it was upgraded at some point when it was in AZ?
Problem is I cannot find a drier that will fit. It has 16MM connectors but the ones I found from Four Seasons do not work because the ID is too small for the hose to fit in. Any suggestions?
'88 Dodge Raider with only 52,000 miles! My upgrades: Curt 2" receiver tow hitch Re-undercoated the wheel wells Gen 2 padded center console cover "armrest" Highland all-weather front mats Double DIN JVC Receiver Power locks with remote
Re: OEM AC Receiver Drier does not fit on my GEN1
[Re: sechack]
#1050320
08/25/12 04:08 PM
Most likely dealer add on then. Time to break out the Four Season picture book, or see The Hose Man. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: rxinhed]
#1050321
08/25/12 05:26 PM
According to Four Seasons the only other possibility is a part number 83175. It has a .395 ID with 16mm fittings.
But it is aluminum and I am concerned it might not seal properly because the old one had .330 ID
[Re: sechack]
#1050322
08/25/12 06:44 PM
Contact this guy - http://www.acsource.com/index.aspxHe used to offer dryers on the site but only a couple are listed now that don't apply here. I'd email him to see if he can source one for you.
[Re: pcc]
#1050323
08/27/12 07:11 PM
Thanks for the comment about a dealer installed option. I looked through the paperwork I got with truck and there it was. The AC was installed by ARA of Phoenix when new. I do not know if they are still in business, but I sent them an email asking about the part numbers I had. http://www.arasourcing.com/motor_vehicle_air_conditioning_driers_acumulators.html
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.6070 MB (Peak: 0.6717 MB) Data Comp: Off Server Time: 2026-11-03 13:35:55 UTCValid HTML 5 and Valid CSS
