Forget P1121 & BOB, what's P1123 & P1127 #1050392 08/27/12 12:11 PM
BAZINGA Offline OP
The following info is from kiatechinfo
P1121 TPS circuit from ECM and TCM
Related Items
ò Short to GND or B+ between ECM and 1CM.
ò Open Between ECM and TCM.
With ignition off, disconnect C211 from ECM and C229 from 1CM. Connect adapter cable #K99U2103-G17 to BOB and vehicle C229 to adapter cable (leave adapter cable 0229 disconnected from TCM). Measure resistance between BOB-20 and C211-38 (less than I ohm).
What does this mean, what is BOB and how can I check without his help?
<img src="/forums/images/graemlins/confused.gif" alt="" />
99 Auto Sportage. Wildcat Extractors, Lukey Turbo Muffler, Warn manual hubs, K&N Air filter, Tyres 30/9.5/15, Ironman 40mm springs, KYB front struts & rear shocks, GME TX3220 UHF radio, dual battery system. Twin 10" electric fans. Next Job: Body lift
Forget P1121 & BOB, what's P1123 & P1127 [Re: BAZINGA] #1050393 08/28/12 09:14 AM
BAZINGA Offline OP
Weird...
I reset the cars computer and...
it coughed and spluttered then died. After several attempts to get it going, and keep it going with pedal depressed and some high revs, I had to take it for a drive. After 30 minutes of driving the car found some settings to at least make it driveable. I plugged back into the computer and read the codes P1123 and P1127 ???
Kiatechinfo doesn't list these codes.
All this has just started since I replaced the idle air control valve and mass air flow sensor with new ones. I also cleaned the K&N air filter.
What are these codes?
Re: Forget P1121 & BOB, what's P1123 & P1127 [Re: BAZINGA] #1050394 08/28/12 09:17 AM
BAZINGA Offline OP
I forgot to mention about the TPS. I gave it a bath with electrical contact cleaner. It seems to have fixed itself - no more P1121
Re: Forget P1121 & BOB, what's P1123 & P1127 [Re: BAZINGA] #1050395 08/30/12 04:21 PM
Peabody Offline
Check out this thread: http://www.4x4wire.com/forums/showflat.php?Cat=&Number=1044374&Main=1044370
Those codes all point to fuel ratio issues. If all the codes started popping up after washing down the engine(?), then I'd suspect one or more of the plugs on the fuel/air system are grounding or faulting due to moisture (TPS, MAF, MAS, etc). The thread I've noted above ended up being a product of mud on the MAF. A few cleanings and it was fine - though it could have been cured by the connector drying during the process of cleaning. I know there's no specific advice here. But those are some areas to check. Hope that helps...
<img src="/forums/images/graemlins/patriot.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6053 MB (Peak: 0.6616 MB) Data Comp: Off Server Time: 2026-06-07 07:26:47 UTC
