Page 1 of 6 1 2 3 4 5 6
95 Front Pads and Rotors Replacement ?s #1051114 09/07/12 08:24 PM
TheViper Offline OP
Im going to be doing my front pads and rotors next weekend, and i have a couple questions that the FSM didnt seem to cover.
1)how do the front rotors come off, do they just pull off once you have the caliper removed?
2)any special instructions or tips i should know about completing this job?
1995 Montero SR
Re: 95 Front Pads and Rotors Replacement ?s [Re: TheViper] #1051115 09/08/12 02:07 AM
To pull the rotors for a turn, you must disassemble the outer hubs assembly. This involves removing the drive flanges, bearings, caliper, etc. as with any contemporary 4wd. Look through the front wheel bearing service list and you'll get the idea.
It's also a good time to consider replacing the drive flanges with manual hubs if you don't have the AWD t-case.
Re: 95 Front Pads and Rotors Replacement ?s [Re: TheViper] #1051116 09/08/12 02:29 AM
geocrasher Offline
http://tidbitsfortechs.com/
Re: 95 Front Pads and Rotors Replacement ?s [Re: geocrasher] #1051117 09/08/12 02:40 AM
TheViper Offline OP
OH MY! thats looks really involved, can a less then mechanically inclined person do this???
1995 Montero SR
Re: 95 Front Pads and Rotors Replacement ?s [Re: TheViper] #1051118 09/08/12 03:27 AM
Grasscat Offline
OH MY! thats looks really involved, can a less then person do this???
Yes, but you are messing with something that could cause serious health issues if not done right.
Get someone that's more mechanically incline to help you.
Michael j
TreadLightly! Trainer
Re: 95 Front Pads and Rotors Replacement ?s [Re: TheViper] #1051119 09/08/12 04:21 AM
In addition to Michael's suggestion I'd also download the gen 2 fsm (factory service manual) which goes through the process pretty well.
Re: 95 Front Pads and Rotors Replacement ?s [Re: off-roader] #1051120 09/08/12 07:48 PM
TheViper Offline OP
ok looked over the fsm (section 26?), the fsm is saying i need some special tools...snap ring pliers and a lock nut removal tool. Are these tools necessary for this job?
1995 Montero SR
Re: 95 Front Pads and Rotors Replacement ?s [Re: TheViper] #1051121 09/09/12 12:19 AM
You can use a fine flat blade screwdriver to pry up the c-clip and then pull with pliers. The bearing retaining nut can be removed with a drift and light hammer taps.
The right tools make the job nicer, but any shop would likely use what is on hand.
Re: 95 Front Pads and Rotors Replacement ?s [Re: rxinhed] #1051122 09/09/12 01:17 AM
TheViper Offline OP
im sorry for my ignorance but what is a "drift"
1995 Montero SR
Re: 95 Front Pads and Rotors Replacement ?s [Re: TheViper] #1051123 09/09/12 03:57 AM
Grasscat Offline
A punch.
Do a search for drift tool or punch tool.
Michael j
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6434 MB (Peak: 0.7669 MB) Data Comp: Off Server Time: 2026-06-20 21:36:52 UTC
