92 SR Towing - brake upgrade? #1051220 09/09/12 05:53 PM
m4ff3w Offline OP
I've read that the '95 Monteros had a tow rating of 5000lbs across the board. I did some searching and see that my '92 SR uses a thinner front rotor than the '95 trucks.
I tow a dolly w/out brakes and would never exceed 5000lbs.
Can I upgrade my '92 to later brakes and safely tow 5000lbs w/out trailer brakes?
92 Montero SR
84 Maserati Biturbo
89 Mercedes 190E
77 Fiat X1/9
Re: 92 SR Towing - brake upgrade? [Re: m4ff3w] #1051221 09/10/12 01:17 AM
Grasscat Offline
I will only answer part of your question. Yes you can upgrade your breaks to the later breaks. I don't know about towing 5000 lbs without trailer brakes, but I know this, I don't and I will not.
Michael j
TreadLightly! Trainer
Re: 92 SR Towing - brake upgrade? [Re: m4ff3w] #1051222 09/10/12 01:37 PM
P
pcc Offline
Was that (5000lb) a tow rating or a combined weight rating?
My recent trailer purchase was fraught with compromise. I have a Ford Ranger with about double the tow rating of the Montero, but with less power to pull, but the brakes on the Ranger are twice as good as the Montero. Getting a 5000 lb capacity trailer means less load weight, adding brakes also adds weight that has to be deducted from load max. Calculating total safe trailer capacity means the Montero can only handle 750lbs while the Ranger can handle 1600lbs, on a trailer with a 3500lb axle.
I also would never tow 5000 lbs, on either vehicle. If I needed that much capacity I'd rent a larger truck.
Do the 95 brakes have larger pad area?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5941 MB (Peak: 0.6472 MB) Data Comp: Off Server Time: 2026-06-07 06:09:09 UTC
