Lubricating the Universal Joints #1051802 09/21/12 08:23 PM
HarleyJohn Offline OP
I'm I crazy? I'm connecting the grease gun up to the zerk fittings on the front universal joints, and it apears that they are "smaller" than a standard zerk fitting. Is this a small size, and if so, is there perhaps an adapter that would allow the standard fitting on a grease gun to work on these zerk fittings?
If so, does anyone have a source or part number for such a thing?
It appears as if all the grease is pushing around the zerk fitting instead of going into the universal joint. But maybe it is just me. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Lubricating the Universal Joints [Re: HarleyJohn] #1051803 09/21/12 11:16 PM
DRX350 Offline
Good luck...
I search far and wide for that imaginary tool, doesn't exist.
So, I waited until they failed and got a new drive shaft and U-Joints for $155. These new U-Joints have the zerks on the outside. It's awesome.
"Does this part need to be in there?"
1996 Dodge 1500 single cab / short bed, 5.9 4x4; 2" lift (springs not blocks), C.A.I and more mods to come.
Re: Lubricating the Universal Joints [Re: HarleyJohn] #1051804 09/24/12 05:37 PM
DennisThompson Offline
I don't think the zerk is smaller just the space to fit the grease gun. I filed the end of my grease gun to fit better.
hope that helps, Dennis
Re: Lubricating the Universal Joints [Re: DennisThompson] #1051805 09/24/12 09:44 PM
There apears to be ample room for the grease gun fitting, it just doesn't seem to "lock" onto the zerk fitting.
Curiouser and curiouser. Thanks.
Re: Lubricating the Universal Joints [Re: HarleyJohn] #1051806 09/28/12 06:52 AM
Sportege_Panicmech Offline
That sometimes happens with greasing fittings. you can replace the zerk fitting with a new one. It's usually an 7 or 8mm or 1/4" socket to remove the old one. ask parts store if they sell them first cause i've never bought them from a parts store. I always take them off used axles at the shop i work at and save them for such occasions as this.
Re: Lubricating the Universal Joints [Re: Sportege_Panicmech] #1051807 09/28/12 07:48 PM
Cool, thanks. I'll try that. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6110 MB (Peak: 0.6812 MB) Data Comp: Off Server Time: 2026-06-07 07:19:25 UTC
