Clutch fork floating?? #1051844 09/22/12 11:41 PM
dave1223 Offline OP
Seems like the clutch bracket is good and a fellow pulled a boot from under my 86 Toyota truck 4x4 2.4 and said the clutch fork is floating.Guess this would explain the non/hard shifting issue?How long does it take to remove the tranny,check and fix the fork and replace the tranny?Guess it could be the fork clips or broken fork? Is there also a spring on there?<img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Clutch fork floating?? [Re: dave1223] #1051845 09/24/12 02:05 AM
kewlynx Offline
This is for a '93:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/clutch/7clutchun.pdf
5 hours, give or take
Rent a tranny jack and a 24" extension to break the top bolts loose.
Buy the beer and pizza
**ubi apis- ibi salus**
Re: Clutch fork floating?? [Re: kewlynx] #1051846 09/24/12 11:46 AM
dave1223 Offline OP
Thanks....
Re: Clutch fork floating?? [Re: dave1223] #1051847 09/24/12 07:32 PM
4Crawler Offline
Might be the clips have fallen off or broken:
- http://www.marlincrawler.com/clutch/release-pilot/clutch-collar-retaining-clips
About 11 years ago in Moab, that happened to one guy and he was able to R&R on the trail, just slid the tranny/t-case back a few inches. We even fashioned a new clip out of a stainless steel band clamp, I think he had one clip on there and the other one was missing.
Re: Clutch fork floating?? [Re: 4Crawler] #1051848 09/24/12 10:17 PM
dave1223 Offline OP
Good info,hope it's something simple.Someone else will be doing the checking/and or work....thanks fellows.
Re: Clutch fork floating?? [Re: dave1223] #1051849 09/25/12 03:15 PM
dave1223 Offline OP
Well my friend saw metal particles in there and said it's likely from the throwout bearing,so I guess it's time for an Aisin clutch kit when money is available.
Re: Clutch fork floating?? [Re: dave1223] #1051850 09/29/12 05:59 AM
toyrunner Offline
Just go buy the LUK kit. About a Benjamin and well worth it. Most auto parts stores should have it in stock.
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: Clutch fork floating?? [Re: toyrunner] #1051851 09/30/12 12:00 PM
Adam F Offline
Rock auto has an Aisin for $110
97 4R, stock, daily driver
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6227 MB (Peak: 0.7055 MB) Data Comp: Off Server Time: 2026-07-16 03:24:36 UTC
