1989 Dodge Raider V6 - Throttle Body - Wanted!
#1052001
09/26/12 11:40 PM
If anybody out there has a Throttle Body for a 1989 Dodge Raider V6 please let me know! Thanks!
1989 Dodge Raider - V6 - Manual - 4x4 - AC - 31" Tires
Re: 1989 Dodge Raider V6 - Throttle Body - Wanted!
[Re: goldenprospector]
#1052002
09/27/12 12:14 AM
If anybody out there has a Throttle Body for a 1989 Dodge Raider V6 please let me know! Thanks! Maybe check if Jay Ayala (just posted today) has that part available?
[Re: off-roader]
#1052003
09/27/12 12:17 AM
Please post wanted items in the "wanted parts section. http://www.4x4wire.com/forums/postlist.php?Cat=0&Board=UBB16Also please Private message individuals that you wish to have dealings with, or communicate with in a 1 on 1 manner. Thanks!, and again, Welcome to the wire.
[Re: LandRaider]
#1052004
09/27/12 04:20 AM
Thanks! Will do to both! <img src="/forums/images/graemlins/kewl.gif" alt="" />
#1052005
09/28/12 12:04 AM
Who told you you need a throttle body???? Did they do a propane test for cracks and leaks. A T.B. wouldn't wear out unless someone drove it in a sandstorm without an air filter. 3 parts ON the T.B. can wear out :Throttle Position Sensor(electric), Idle Control Servo (electric) and wax pellet in the hot water system thru the T.B. '89 T.B. is specific to '89 only in CA and 49 states. It may have been used on '91 CA Mighty Max( CA only).
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: KrzyDav]
#1052006
09/28/12 02:15 PM
The previous owner said that the high idle i'm experiencing must be because of the throttle body. he said he replaced the IAC and all vacuum hoses and thinks that he's narrowed it down to the throttle body. I bought from a guy out in the california desert so sand is a possibility. I read a few post where people replaced there TB and it fixed their problem, so I figured I'd give it a try. Dont think he did a propane test.
Pretty sure the engine is stock...I can take a photo if u want.
#1052007
09/28/12 02:39 PM
Have you tried spraying it all down with carb cleaner to see if you can get a change in idle? Including the master cylinder hose?METALMOVER
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
[Re: METALMOVER]
#1052008
09/28/12 08:20 PM
No actually I haven't tried that.
Just an update, I found the part! Thanks to everyone who helped!
