Thinking of replacing the interior door panels
#1052054
09/28/12 11:23 PM
I would like to replace the interior door panels with some diamond plat or at least something that isn't torn up. How the heck does one remove the window winder handle?! Is it clipped or just bruit force....HELP!
You maybe younger and can run faster, but I am older and have been around long enough to know where all the shortcuts are!
1989 MTs/Dodge Raider SWB V6 5spd - Daily Driver/Work in Progress.....
Re: Thinking of replacing the interior door panels
[Re: RaiderGriz]
#1052055
09/29/12 12:40 AM
Mine have all been power windows but IIRC from other discussions there's a circlip holding it in place. The door handle bezel also has a screw in it.
[Re: off-roader]
#1052056
09/29/12 02:32 AM
It's easy to pull the circlip. Take a shop rage and use a shoe shine motion behind the bezel of the window winder handle. It will catch the prongs on the clip and slip it loose. To reinstall is even easier. Put the clip on the handle slots and pop it on the shaft. The taper on the end of the shaft will open it enough to slide down to the groove.
[Re: fasteddy]
#1052057
09/29/12 03:51 AM
I suggest using a shop rag, or a fine-blade flat screwdriver, to remove the circlip. Leave the rage where it belongs, on the freeway, workplace, and county-western bar.
[Re: rxinhed]
#1052058
09/30/12 04:16 AM
No, if you don't get mad, it won't come off...
[Re: fasteddy]
#1052059
10/01/12 04:57 PM
I remember my 69 bronco and I installed some diamond plate door cards. They were nice. On the montero it may be a little flashy unless you add more diamond plate or chrome accents to the interior. good luck with ti and post some pics when you get it done.
[Re: RECON45]
#1052060
10/01/12 06:38 PM
Agreed, just want something that's not beat up.  Bead-board? LMBO
[Re: RaiderGriz]
#1052061
10/01/12 06:47 PM
Aluminum panel would be nice. Easy on the cutting tools too since you can use woodworking tools to cut it. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: RaiderGriz]
#1052062
10/01/12 07:55 PM
Do you want something that is more ruggedized like diamond plate? If not, then just recover the ones you have, or scrounge from the yards if you have any local.
[Re: MontyMcV]
#1052063
10/01/12 08:18 PM
Do you want something that is more ruggedized like diamond plate? If not, then just recover the ones you have, or scrounge from the yards if you have any local. If the original wood is broken and you can't find them in the yards you can also easily make them. The wood is available at HD, Lowes, etc. <img src="/forums/images/graemlins/kewl.gif" alt="" />
