Does your TB have a wax pellet style FIDLE valve like the 3.0 in addition to the isc?
dont believe it does. For a TB, it's very very small and very very basic. not much to the damn thing once you remove the idle motor assembly. that's the other thing ... with either set of idle speed motors and position sensors, neither motor is engaging the butterfly. something else is revving the thing up.
Has the idle bypass screw been fooled with?
It's entirely possible - although I havent. At one point my mechanic had the thing before I did the exhaust (complete incl. manifold to tailpipe) to recharge the AC, asked him to diagnose rough idle.... he said original throttle body had a bad vacuum leak. Got another one from a maxd50scene forum guy, he installed it for me (travelling on biz at the time) said that one was good. he may have adjusted the idle screw to the extreme, which at the time the truck still had a bad ecu... so we were fighting a bad ecu at the time. Ignoring what the wonky FSM might say - where should I start on the screw? about 50% point of range? back it all the way down and maybe start low at 20 or 30% of max? never really had to mess with those screws so I'm a bit green in that area... where it should be, how much it alone can impact the rpm's (all the way to 4500?)
Has the mechanical idle stop screw been molested? What is the idle stop opening (measure with drill bits, gap from buttfly to bore wall)
She's cracked open a bit. When i last looked at it Tue night, I'd say maybe it was cracked open about 1/8" or so. About the same as original throttle body on my shelf actually. Will recheck this and maybe also play around with the idle screw..
jim
