Cold start problem. 89 3.0 #1052373 10/09/12 06:31 PM
hampster Offline OP
Takes a lot of turns for my old 89'3.0 to fire after sitting over-nite or thru a shift at work. Once she fires she starts on first crank every time.
Re: Cold start problem. 89 3.0 [Re: hampster] #1052374 10/09/12 08:03 PM
Test ecu coolant temp sensor, on water neck at thermostat, points forward with two connecotrs in a tee shape. Cheap part at autozombie or advanced, around $30.
Re: Cold start problem. 89 3.0 [Re: fasteddy] #1052375 10/09/12 08:35 PM
8
89Monty Offline
Had same issue with mine when I first got it...I replaced the coolant sensor, and cleaned the IAC and the port it seats into. Throttle body was gunky also. After that all was clean, I reconnected battery, and walla...no more issues for me...
Re: Cold start problem. 89 3.0 [Re: 89Monty] #1052376 10/09/12 10:08 PM
hampster Offline OP
Thanks to both for the answers. That should fix me up.
Re: Cold start problem. 89 3.0 [Re: hampster] #1052377 10/11/12 02:43 AM
Ecu uses ect sensor to determine cold start enrichment. When it's bad, it usually fails in such a way that the ecu doesn't know the engine is cold, so no cold start enrichment. As a consequence, the starting mixture is too lean to fire off cold. This usually starts showing up when the weather starts to turn colder, like lately...
In a few cases, I've seen the ect fail so the engine thinks it's cold when it's not, and you run very rich...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6046 MB (Peak: 0.6684 MB) Data Comp: Off Server Time: 2026-06-23 13:08:42 UTC
