Raider/Mitsu 2.6: Weber, Dieseling. How to correct? #1052468 10/11/12 11:25 AM
TresMon Offline OP
So when I shut down the motor it likes to start running backwards dieseling.
How to correct this?
Thanks
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Welded front,tight LSD in the rear
Removed bump stops
4'x6' roof rack
10k. Lb. winch on receiver hitch/custom bumper
100 amp alt
CB radio/AC inverter
S.Winch hubs
Enormous RV battery
Re: Raider/Mitsu 2.6: Weber, Dieseling. How to correct? [Re: TresMon] #1052469 10/11/12 12:49 PM
socal1200r Offline
You're running the Weber 38, yes? Not sure how much this would apply, since I'm running the 32/36, but same principal I would assume.
1. Make sure the fuel/air screw is set correctly. If you bought your carb new, this should be covered in the installation instructions. From what I remember, you have to start with the screw being so many turns out, then with the car at operating temp, turn the screw in until the motor starts running rough, then back it out like a half turn or something like that. That will get you in the ball park.
2. Adjust the idle set screw. On my 32/36, it would diesel at anything above 700 rpms. After you set the fuel/air screw, adjust the idle so it's just a tad above the second line on the tach. Any higher and mine usually would diesel, any lower and the steering wheel would shake at idle. That should get you close, maybe within 1/4 to 1/8 turn on the idle screw. Also, I've learned to use mid-grade gas, that helped a lot with my dieseling issue.
Good luck!
1989 Monty SWB, 2.6L w/MT, 15" alloys, 265/75 Dunlop Radial rovers, rear air shocks, Weber 32/36, SQ oil cooler, (SOLD Oct 2012)
Southeast VA, USA
Re: Raider/Mitsu 2.6: Weber, Dieseling. How to correct? [Re: TresMon] #1052470 10/11/12 01:05 PM
METALMOVER Offline
If you are running the Weber carb, do you have a good fuel pressure regulator? Not the dial kind, but a 3-5lb holley? If not Id start there. Good luck, METALMOVER
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
Re: Raider/Mitsu 2.6: Weber, Dieseling. How to correct? [Re: METALMOVER] #1052471 10/11/12 05:46 PM
socal1200r Offline
My '89 Monty with the 2.6L and 32/36 Weber has 170K miles, and runs fine with the stock fuel pump. Start with those carb adjustments first and a tank of mid-grade gas, and see if that cures your dieseling problem. The carb adjustments don't cost anything, and mid-grade gas is what, .10 a gallon more than regular? Give it a try, and see what happens before spending money on a new fuel pump.
Southeast VA, USA
Re: Raider/Mitsu 2.6: Weber, Dieseling. How to correct? [Re: socal1200r] #1052472 10/11/12 09:44 PM
This ahs been ocvered before. THe weber meeds a lower fuel pressure than the internally regulated pressure from the mitsu fuel pump. The mitsu pump has two outlets and one suction. One outlet is regulated to around 7-8psi and goes to the mikuni float bowl (high front center of the carb). The unregulated bypass goes to the lower dside front (iirc) of the carb, thru the auz accel pump fuel reservoir, and then to the fuel return line to the tank. You need to put another pressure regulator on the first regulated line set to the pressures noted above.
What is happening is that the fuel pressure is pushing the needle off the seat and overflowing the fuel bowl into the carb throat. The constantly over rich mixture is carboning up the combustion chamber. The carbon deposits get white hot, and ignition source, and the leaking fuel and the ignition source make the engine diesel. Fix the fuel pressure, and then fog water spray into the carb throat with the engine at high idle to remove the carbon deposits, preferably with the exhaust disco'ed from the cat.
Re: Raider/Mitsu 2.6: Weber, Dieseling. How to correct? [Re: fasteddy] #1052473 10/17/12 09:43 PM
tolyho Offline
The FPR METALMOVR is mentioning is the Holley 12-804. Just picked one up. Hate to say it SoCal1200R but every time I drive this thing I think I'm going to light up with the amount of gas fumes I get on me. Love the rig, tho! Putting the FPR on tonight to see the difference. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Chris -
Re: Raider/Mitsu 2.6: Weber, Dieseling. How to correct? [Re: tolyho] #1052474 10/17/12 11:31 PM
TresMon Offline OP
Installed a 1-6psi FPR. It did NOT stop the dieseling and caused other significant problems.
That topic is here...
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Removed bump stops
4'x6' roof rack
100 amp alt
S.Winch hubs
Enormous RV battery
Re: Raider/Mitsu 2.6: Weber, Dieseling. How to correct? [Re: TresMon] #1052475 10/18/12 01:41 AM
tolyho Offline
I just noticed the post after replying to this one. Also since then I installed the Holley unit mentioned before. After the "steam" clean I checked the timing, went through the initial settings on the Weber for Fuel/Air and Idle then tweaked to my ears and the results were very positive. Easily a 20% increase in power across the band, no hesitation between 2600 and 3k RPM, after letting it idle (high for a bit then adjusted to 650) the unburnt fuel smell was completely gone. Last but not least... no more dieseling. Just my experience and could be totally different for you if you have different gear(of course). Oh, I had the FPR set just under 2.5lb
Good Luck
Chris -
Re: Raider/Mitsu 2.6: Weber, Dieseling. How to correct? [Re: tolyho] #1052476 10/18/12 03:52 PM
Brad_Thurston Offline
Do you have any pics of the install. I am about to try installing the 804 to cure my issues and am interested in seeing where you mounted.
Re: Raider/Mitsu 2.6: Weber, Dieseling. How to correct? [Re: Brad_Thurston] #1052477 10/18/12 10:55 PM
tolyho Offline
I'll snap some pics this weekend. I need to clean up a lot of stuff under the hood on Saturday or Sunday and I'll get a few for you. Once I pull all of the factory vac stuff out there will be plenty of room on the driver's inner fender whether it's flat or horizontal.
Cheers!
Chris -
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6413 MB (Peak: 0.7679 MB) Data Comp: Off Server Time: 2026-11-02 08:29:16 UTC
