Re: Raider/Mitsu 2.6: Weber, Dieseling. How to correct? [Re: tolyho] #1052478 10/22/12 01:23 PM
Brad_Thurston Offline
I just installed my 12-804 holley fpr last night. Previously, trip home from mechanic after getting gas tank cleaned raider died(possibly flooded out) going down highway at least 6 times. I drove the raider to work this morning, 34 miles and not a single hiccup. The FPR is set right now at 2psi. No dieseling now either.
Re: Raider/Mitsu 2.6: Weber, Dieseling. How to correct? [Re: Brad_Thurston] #1052479 10/22/12 06:05 PM
tolyho Offline
That's SWEET Brad! I was able to find the fine line of adjustment between the FPR, Fuel/Air and Idle this weekend on my journey. I drove over a couple of mountains(2400' up/down), around some towns and normal 40-45 puttin'. I would stop about every 100 miles and make a slight adjustment on the Fuel/Air and idle until I saw these steps in power and fuel mileage return: 15-16 on purchase, 18 on highway after FPR, 20.6mpg mixed driving on the most recent tank including two trips (to and back) over the mentioned mountain, 100 miles of highway and rest city.
Tresmon- maybe there's an issue with your Mr. Gasket FPR?? Seems to be adding issues exactly where's it's suppose to help.
Chris -
Re: Raider/Mitsu 2.6: Weber, Dieseling. How to correct? [Re: Brad_Thurston] #1052480 10/23/12 06:44 PM
cdl1701 Offline
I have been having this problem for the past year on and off and figured that it had something to do with the dial FPR that I have on it. Did you have to get anything else to go with the 12-804 holley fpr to get it to work like fittings or a pressure gauge?
88 Montero, 2.6 Black
Re: Raider/Mitsu 2.6: Weber, Dieseling. How to correct? [Re: cdl1701] #1052481 10/25/12 03:50 PM
tolyho Offline
I did add a pressure gauge a couple of days ago but when I initially set it I just cranked the valve all the way in and then backed out 3 full turns as a guess. The shop next door allowed me to use there pro gauge to check it the next morning and that's where I got the original reading from. Since adding the "permanent" gauge I have a consistent check if I need it. Since the Holley has dual outputs it's easy to add-on. Additional parts other than that was the 3/8th's NPT to what ever size fuel hose that you're using and either the gauge or a cap to close the second output. After you do this; clean the carb from carbon the best you can (carb cleaner, steam trick, etc..), check your timing and use the Weber initial set guide for Fuel/Air and Idle.
Cheers!
Chris -
Re: Raider/Mitsu 2.6: Weber, Dieseling. How to correct? [Re: Brad_Thurston] #1052482 11/01/12 02:54 PM
tolyho Offline
Do you have any pics of the install. I am about to try installing the 804 to cure my issues and am interested in seeing where you mounted.
Forgot to post this: [Linked Image]
Chris -
PHP: 7.4.33 Page Time: 0.013s Queries: 17 (0.010s) Memory: 0.6145 MB (Peak: 0.7117 MB) Data Comp: Off Server Time: 2026-11-03 12:28:24 UTC
