T100 squeaking when turning #1053037 10/23/12 10:02 PM
T100mike Offline OP
I was wondering if anyone could help me out with the problem I seem to behaving with my 95' T100. Anytime I go to turn the wheel hard either right or left I get a loud squeaking or squealing sound. At first it was doing it just a little bit but it has been getting worse. Any help would greatly appreciated.
1995. Toyota T100 DLX. 4x4. Auto
1995 T100 4x4 DLX EXC
Re: T100 squeaking when turning [Re: T100mike] #1053038 10/23/12 11:51 PM
BamZipPow Offline
It's probably the bump stops. You can grease them or buy some aftermarket ones on eBay fer $32 shipped. <img src="/forums/images/graemlins/smile.gif" alt="" />
http://www.ebay.com/itm/86-95-TOYOTA-Pickup-4-Runner-all-T100-Steering-Stops-/221142145463
Re: T100 squeaking when turning [Re: BamZipPow] #1053039 10/24/12 10:22 PM
ErikB Offline
Toyota Moderator
If the squeaking is coincident with suspension movement (hitting bumps, etc.) when at full turn left or right, then greasing the steering stops should solve it.
Otherwise, from your description it could also be as simple as a loose power steering belt or being low on power steering fluid.
http://home.4x4wire.com/erik
Re: T100 squeaking when turning [Re: ErikB] #1053040 10/25/12 12:56 AM
T100mike Offline OP
Thanks Bam and Erik for getting back to me.
Bam thanks for the link. I had a look and they are def. rubbing so I ordered some of the bumper stops see if they help.
Erik I had checked the power steering fluid and its full. I'll have a look at the belt and see if its loose. Hopefully the bumper stops will fix the problem.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6022 MB (Peak: 0.6581 MB) Data Comp: Off Server Time: 2026-10-24 03:24:24 UTC
