Check Engine light came on #1053047 10/24/12 12:00 AM
Bent_85 Offline OP
My 91 v6 had the "check engne light" come on this morning. I've got a newer O2 sensor with about ~100,000km on it. Also a newly oiled K&N filter. I haven't checked any codes. Does anyone know why the light comes on?
91 Toy 4x4 V6
85 Toy 4x4 22R
Re: Check Engine light came on [Re: Bent_85] #1053048 10/24/12 06:40 AM
4Crawler Offline
Re: Check Engine light came on [Re: 4Crawler] #1053049 10/26/12 06:13 PM
Bent_85 Offline OP
Thanks 4Crawler,
I got a code 4 - 2 which I guess is 42 and which from the chart on your site gives:
VEHICLE SPEED SENSOR SIGNAL CIRCUIT--NO SPD. SIGNAL FOR SEVERAL SECONDS
WHILE VEHICLE IS OPERATED UNDER HEAVY LOAD (TPS/MAP/AIR FLOW INPUTS)
--SPEED SENSOR/CIRCUIT
--ECU
I didn't know there was a speed sensor unless its picked up by the rear axle anti lock brake system?
I was going about 125km/hr.
Thx
91 Toy 4x4 V6
85 Toy 4x4 22R
Re: Check Engine light came on [Re: Bent_85] #1053050 10/26/12 07:06 PM
G
Greg_Canada Offline
The speed sensor is in the speedometer... it outputs to the ECU.
89 4Runner
Re: Check Engine light came on [Re: Greg_Canada] #1053051 10/26/12 09:49 PM
Bent_85 Offline OP
I believe you but, my 91 has the standard mechanical speedo which unlike the newer 93? and up which have the electronic pick up at the rear trany output shaft. If my speedo has a bit of bind up (where the speedometer wobles at low speeds) do you guys think that could be the problem for this code?
I also have a lot of kilometers on this truck; now just reaching ~600,000km. The drive shaft has recently gotten some vibration in it and that is very likely from the hanger bearing. Rubber dampner pops out of the holder and has to be stuffed back in and then it's quiet. Is this code just from pushing it or something else? Thanks again!
91 Toy 4x4 V6
85 Toy 4x4 22R
Re: Check Engine light came on [Re: Bent_85] #1053052 10/27/12 03:31 AM
4Crawler Offline
The VSS is on the back of the speedo as noted if you have a mechanical unit. The ECU gets that signal as does the cruise control module, if you have that. Also for the A/T ECU if you have an automatic. Since the VSS is driven off the speedo cable, the binding you see might be related to that. Maybe try lubing tbe cable or replace it if needed. Center bearing can be replaced or you can eliminate it with a one-piece drive shaft.
Re: Check Engine light came on [Re: 4Crawler] #1053053 10/27/12 08:26 PM
Bent_85 Offline OP
Hi 4Crawler, The instrument pannel is "upgraded" over my old base package. There is no cruise and I have a 5 speed.
I did lubricate the cable a while back with some very low viscosity synthetic oil as I was trying to reduce the speedometer needle vibration. It took care if most of it but not all of the vibration. I'll look for a newer speedo cable and get a new hanger bearing and see what happens.
Thanks
91 Toy 4x4 V6
85 Toy 4x4 22R
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6231 MB (Peak: 0.7134 MB) Data Comp: Off Server Time: 2026-05-29 23:57:20 UTC
