help from the gurus please #1053088 10/24/12 04:18 AM
goobuds Offline OP
so i took it apart with out marking it now i dont know how it goes back the Manuel says there both marked. there not.
this is the oil pump side see the mark on the cog. [Linked Image]
this is the shaft side no mark
although this is out of my spare block. i took it a part to see what and how. my raider has had high oil psi (90) hot or cold. and has a lot of pressure in crank case. not to mention little oil slick from the front cover. so i took things apart. timing cover, belts fans.
looking around noticed oil around top plug on lower silent shaft. spun the shaft and it just spun nice and smooth like a bearing thought nothing of it then spun the other and relized there was no counter weight spinning was going to jump right in at tear it a part to find out why. but stop becuse its not in the garage and might as well wait intell i get a gasket kit. so pulled the spare block to see what my be. but now if i need to realine it i have nothing to go off of.
owned a few .. current 86 rustbucket 2.5td . manual hubs
Re: help from the gurus please [Re: goobuds] #1053089 10/24/12 09:14 PM
Can't see the pics...
Re: help from the gurus please [Re: fasteddy] #1053090 10/24/12 09:26 PM
goobuds Offline OP
umm i hope they can be seen. please inform me if they can not.
and thanks to rollguy. for the answer i needed
the silent shaft gear is marked on the other side.
and here is a link to the pics 4d55
Re: help from the gurus please [Re: goobuds] #1053091 10/24/12 11:56 PM
justice Offline
pics no work
Re: help from the gurus please [Re: goobuds] #1053092 10/25/12 05:54 AM
captain_orange Offline
Here you go:
1989 Raider - V6, Tan
www.lewisfab.com
www.palatov.com
Re: help from the gurus please [Re: captain_orange] #1053093 10/25/12 07:59 AM
goobuds Offline OP
thank you i was going to try to redo it i was busy trading.
so heres to you <img src="/forums/images/graemlins/cheers.gif" alt="" /> good sir
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6125 MB (Peak: 0.6838 MB) Data Comp: Off Server Time: 2026-06-17 13:26:56 UTC
