Electrical problem - help #1053193 10/28/12 02:35 AM
L
Lor Offline OP
Recently, I was driving my pup and then stopped by the store for a few minutes. I came out and turned the key. Nothing, not even a starter click. I was frustrated for about 5 minutes. I left the pup at the store and walked home. It's only a few blocks away. Later, I went back and it fired up no problem.
Well, yesterday I was heading back home from the mountain. While I was on the interstate, the dash lights went dark. About 5 miles I passed a trooper. He followed me for a mile and flashed the lights. I stopped and he told me that the rear end was dark. This was a bad timing due to the rain and dark. I told him that it could have been a fuse cause it just went out.
I got home and discovered that the fuse to the dash was out. I put another one in and as soon as I turned on the lights, the fuse blown. I tried a 15 amp and same thing. I went through couple with the same result. I tried starting the pup and sure enough, nothing. The starter didn't click at all. I left it alone for several minutes and it started ok again.
What could have cause this problem to short the fuse? Anyone experience anything like this before? I don't have anything on this circuit. I only ran a stereo, but I believe it's on a different circuit. Also the CB is direct from the battery.
I need help. Thanks.
Re: Electrical problem - help [Re: Lor] #1053194 10/28/12 06:48 PM
mlclark Offline
Isuzu Moderator
Time to start looking for the short!
I cannot exactly explain the no-start problem, but repeatedly blowing fuses is not a good thing. Pull the cover off of the instrument cluster and look for pinched or worn wires.
I would also look closely at the harness feeding the ignition switch.
I would also try and find the problem before it causes a bigger problem (i.e. fire).
Good Luck
Michael
Re: Electrical problem - help [Re: mlclark] #1053195 10/28/12 07:21 PM
Jim_Paget Offline
This sounds off the wall, but it has happened to me in the past.
Check your trailer wiring. The two are somehow intertwined in a way that only makes sense to an Isuzu engineer.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Electrical problem - help [Re: Jim_Paget] #1053196 10/28/12 08:19 PM
L
Lor Offline OP
Ok, I just checked over all the illumination lights on the front and rear, including wires and bulbs. Didn't see anything. I looked at the trailer wires and electrical taped all the places that I think needs reinforcement. Popped in a 20 amp fuse to the #1 slot (the one that kept blowing yesterday). All lights came on. Replace the 20 amp with a 10 amp. Everything seemed to be back to normal now. I will drive this thing and see if the problem comes back. I have plans to take it to the mountain in the middle of November. Hope it will be ok.
Thanks for the suggestion.
Re: Electrical problem - help [Re: Lor] #1053197 10/31/12 06:56 AM
mlclark Offline
Isuzu Moderator
Check/replace the flasher unit. It usually applies to the Trooper wiring, but like Jim said, there are a few very strange circuits in our vehicles. Although, if it is blowing fuses, it is very likely you have a short somewhere due to a chaffed wire.
Good Luck,
Michael
Re: Electrical problem - help [Re: Lor] #1053198 10/31/12 02:16 PM
BigSwede Offline
Try actually unplugging the trailer light converter, those things are a common problem. The dash lights are on the same fuse as the tail lights, at least this is true for Troopers and Rodeos.
Serenity now!
Re: Electrical problem - help [Re: Lor] #1053199 01/15/13 12:06 AM
smd94trooper Offline
FWIW, my Trooper had a similar situation where the fuse for the fuel pump would pop randomly, most of the time during start-ups but it could be on the road or wherever. Turned out that I had a bad alternator. I had also been having what I thought was a drained battery (probably was never charged properly). All of my weird electrical problems were probably due to the alternator surging or not charging properly.
I have since replaced it and everything is fine.
Good luck!
Stefan Doerr
'94 Trooper LS
6.5" lift, 33's, G80 and other stuff
http://community.webshots.com/user/smd94trooper
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6155 MB (Peak: 0.6945 MB) Data Comp: Off Server Time: 2026-06-21 13:39:47 UTC
