engine stall...
#1053226
10/28/12 08:11 PM
Hi, I was wondering if someone can shed some light on my mystery problem.
For the record I have a 99 cherokee XJ. 4.0 Earlier today I was doing a simple 3 pt turn around. As soon as i let off the gas in reverse, and right before I put it into drive the engine shut off. First I thought I was low on gas, but I had half a tank...
I tried it again after getting gas and it did the same thing. I have been driving for the last couple hours with no problems but this still has me kinda worried.
Any help would be greatly appreciated.
Thanks!
Re: engine stall...
[Re: ldrdl]
#1053227
10/29/12 07:32 AM
I would check out the Throatal Position Sensor. That sensor does have a tendacy to accumulate deposits hat affect engine performance.
Re: engine stall...
[Re: 4x4Wire]
#1053228
10/29/12 11:45 PM
Thanks, ill give it a look.
Also, what happened to all the treads?
Re: engine stall...
[Re: ldrdl]
#1053229
10/30/12 01:22 AM
At the bottom of the menu page is a drop-down menu that allows you to change the time interval for threads. The default is all threads in the past two weeks. There has not been much traffic in the past couple of weeks. Change the interval to a longer period and you will see older threads.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6000 MB (Peak: 0.6551 MB) Data Comp: Off Server Time: 2026-05-29 19:57:58 UTCValid HTML 5 and Valid CSS
