engine stall... #1053226 10/28/12 08:11 PM
L
ldrdl Offline OP
Hi,
I was wondering if someone can shed some light on my mystery problem.
For the record I have a 99 cherokee XJ. 4.0 Earlier today I was doing a simple 3 pt turn around. As soon as i let off the gas in reverse, and right before I put it into drive the engine shut off. First I thought I was low on gas, but I had half a tank...
I tried it again after getting gas and it did the same thing. I have been driving for the last couple hours with no problems but this still has me kinda worried.
Any help would be greatly appreciated.
Thanks!
Re: engine stall... [Re: ldrdl] #1053227 10/29/12 07:32 AM
4x4Wire Offline
I would check out the Throatal Position Sensor. That sensor does have a tendacy to accumulate deposits hat affect engine performance.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: engine stall... [Re: 4x4Wire] #1053228 10/29/12 11:45 PM
L
ldrdl Offline OP
Thanks, ill give it a look.
Also, what happened to all the treads?
Re: engine stall... [Re: ldrdl] #1053229 10/30/12 01:22 AM
4x4Wire Offline
At the bottom of the menu page is a drop-down menu that allows you to change the time interval for threads. The default is all threads in the past two weeks. There has not been much traffic in the past couple of weeks. Change the interval to a longer period and you will see older threads.
John Stewart
Editor - 4x4Voice
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6030 MB (Peak: 0.6581 MB) Data Comp: Off Server Time: 2026-05-30 01:18:59 UTC
