$22 redneck cruise control for Raider. Plus woods tool, winch tool. #1053299 10/30/12 11:18 PM
TresMon Offline OP
SO I have been figuring a good way to bump up the idle on the raider to make more amperage when winching, also to increase idle speed for when the Weber is complaining about off angle 'wheelin. Then I thought it might work for a pseudo cruise control too. I think this can't be beat price wise:
http://www.awdirect.com/in-cab-throttle-cable-ro9d35x10/throttle/
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Welded front,tight LSD in the rear
Removed bump stops
4'x6' roof rack
10k. Lb. winch on receiver hitch/custom bumper
100 amp alt
CB radio/AC inverter
S.Winch hubs
Enormous RV battery
Re: $22 redneck cruise control for Raider. Plus woods tool, winch tool. [Re: TresMon] #1053300 10/31/12 12:38 AM
There was a dealer install option for the 2.6 Montero/Raider for a cruise control, or you might adapt an aftermarket cruise computer/switch to a starion actuator.
Re: $22 redneck cruise control for Raider. Plus woods tool, winch tool. [Re: TresMon] #1053301 10/31/12 12:42 AM
JAVYPRO Offline
Monteros, Gen I, came equipped with a hand throttle but not in good USA. If you notice on the throttle pedal arm there is a loop where the hand throttle connects.
I made mine with a bycicle gear level and it worls great because the one I had clicked into the different gears options.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: $22 redneck cruise control for Raider. Plus woods tool, winch tool. [Re: JAVYPRO] #1053302 10/31/12 04:47 AM
tonygon Offline
if your local pick and pull has semi trucks youre in luck. they come with those hand throttle stock. its a knob that you turn to increase the idle. it attaches directly to the gas pedal. thats what i have for mine but havent installed it yet. i also read that a hyunday sonata v6's higher amperage alternator bolts right up to the gen 1 just have to swap out the pulley. hope this info helps.
1988 MONTERO SWB 2.6L 5SPEEED MANUAL, 96SR LOCKED REAR, 8INCH FRONT LSD FRONT, AISIN MANUAL HUBS, CUSTOM F & R BUMPERS, ROCK SLIDERS, TUBE HALF DOORS, 9K WINCH, HOMEMADE SNORKLE, SOME OTHER STUFF.
Re: $22 redneck cruise control for Raider. Plus woods tool, winch tool. [Re: tonygon] #1053303 10/31/12 12:32 PM
TresMon Offline OP
thanks for the info. per the sonata alternator, do you have to change the voltage reg?
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Removed bump stops
4'x6' roof rack
100 amp alt
S.Winch hubs
Enormous RV battery
Re: $22 redneck cruise control for Raider. Plus woods tool, winch tool. [Re: TresMon] #1053304 10/31/12 01:58 PM
tonygon Offline
I read it was even the same plug! So its a direct bolt on except for the pulley issue. I wish this was first hand info but i didnt find a v6 sonata last time i checked my local yard.
Re: $22 redneck cruise control for Raider. Plus woods tool, winch tool. [Re: tonygon] #1053305 11/01/12 02:02 AM
TresMon Offline OP
Thanks. do you know what year Sonota? I check into a big rig hand throttle. no dice yet without a lot of hassle. but:
http://www.lawnmowerpartsoutlet.com/Push-Pull-Cable-For-Universal-104-Long_p_4504.html
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Removed bump stops
4'x6' roof rack
100 amp alt
S.Winch hubs
Enormous RV battery
Re: $22 redneck cruise control for Raider. Plus woods tool, winch tool. [Re: TresMon] #1053306 11/01/12 03:12 AM
tonygon Offline
i believe i read 95-98 v6 models. that lawnmower cable looks good. i ddont see what the endd of the cable looks like, though. hope it works for you. i need mine to bump the idle when my engine driven compressor kicks in for my onboard air system that im working on.
Re: $22 redneck cruise control for Raider. Plus woods tool, winch tool. [Re: TresMon] #1053307 11/01/12 03:13 PM
tolyho Offline
I used JAVYPRO's idea on two of my older rigs and had the idea to do this one. My reasoning was for off angle/up hill wheeling where I could control the throttle to keep the carb running with one hand(had it connected to the shifter so I could shift and throttle, no clicks-spring return). You could also tighten it quickly to lock the idle up for winching/welding.
I'm interested in the Sonota Alt mod. Got to check that out!
Chris -
Re: $22 redneck cruise control for Raider. Plus woods tool, winch tool. [Re: tolyho] #1053308 11/03/12 04:00 AM
KrzyDav Offline
91 or 2 thru 97 3.0 sonata has the same alternator as my 3.0. I haven't used it. It was in a big box of Sonata part a guy quitting the yard in Excramento gave me. I don't know if that will mount to the 2.6. The amps is 75 or 85.
dave h.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6465 MB (Peak: 0.7663 MB) Data Comp: Off Server Time: 2026-05-29 14:44:10 UTC
