2001 Montero Limited - p0432 code #1053320 10/31/12 02:54 AM
A
Alan_B Offline OP
I have a 2001 Montero limited that codes p0432 which indicates the primary cats are not working. There aren't any other 02 codes so its seems the sensors are OK.
Has anyone replaced this part and where did you get it? Rock auto has the cats in the y pipe for $277 while the mitsu places on line are around $600. I'd like to hear if anyone has used the cheaper parts and what their experience was. Thanks!
Re: 2001 Montero Limited - p0432 code [Re: Alan_B] #1053321 10/31/12 07:18 PM
Alan, do a google search on fixing P0432. I seem to remember a fix with a spark plug saver that moved the O2 sensor out some and fixed the problem. P0432 is triggered (iirc) by a voltage difference greater than allowed between the two O2 sensors in that exhaust stream...
Re: 2001 Montero Limited - p0432 code [Re: fasteddy] #1053322 11/01/12 06:05 PM
MBrannon Offline
+1 on the spark plug spacers. This is a link with some info. You can certainly get them cheaper from Advance auto etc.
http://www.3sx.com/store/comersus_viewItemBundle.asp?idProduct=28938
If your cat is blocked you may want to convert it to off-road use only. If the spacers do not work this is another option:
http://www.3sx.com/store/comersus_viewItemBundle.asp?idProduct=769
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5934 MB (Peak: 0.6469 MB) Data Comp: Off Server Time: 2026-06-07 06:10:38 UTC
