Quick Hello #1053367 11/02/12 01:46 AM
mynion Offline OP
New Montero Owner, just picked up a 94 Montero SR 3.5L
Really excited to take her out and give her a run, going out near death valley next week, Im really excited.
Anything montero specific I should be keeping an eye on? found one with only 123k on her so...
Re: Quick Hello [Re: mynion] #1053368 11/02/12 02:24 AM
sasnydley Offline
Has timing belt/tensioners and waterpump been done? If it breaks on the 3.5 it is catastrophic.
Re: Quick Hello [Re: mynion] #1053369 11/02/12 05:33 PM
Welcome. Track down off-roader and some of the others your way, they'll take care of you... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Quick Hello [Re: mynion] #1053370 11/04/12 04:19 PM
Welcome! I'm pretty sure you'll find this forum to contain the most amount of online technical info on the mitsu 4x4 models sold in N. America bar none.
1st suggestion... Read the FAQ post at the top of this forum. Lots of great tidbits of info. including where to download the factory service manuals (FSM).
2nd suggestion... Put your vehicle info in your signature so you don't have to tell us every time you post questions or updates.
3rd to answer your question...
-inspect and if needed replace all fluids including radiator (flush the system), motor oil, transmission (flush), transfer case, differentials.
-lube all zirk fittings while changing the fluids. There are ~12-13 of them under the rig. You can find a lube points diagram/illustration in the FSM.
-verify the 4wd system works
-verify the last tune up was done using iridium plugs and within 100k. If you can't verify then do one.
-verify the timing belt was done within 100k miles (max)/60k miles minimum. On my rig you can check the belt by unbolting and checking under/behind the plastic timing belt cover. Should be the same/similar in your 94SR.
-Check your battery and alternator.
It was early when I wrote this so ims sure others will chime in with more suggestions... Again welcome!!!
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Quick Hello [Re: off-roader] #1053371 11/05/12 08:08 PM
mynion Offline OP
Hay, thanx all, hay a fellow bay area person, nice.
You have a pretty sweet wright-up, well wright ups on your SR build... I have been looking for the right montero for months and finially found this one. hoping I didnt get a lemon, but only 123 miles on her. will go through and check all those pints best I can, dont have many tools up here, I moved from LA area about a month and a half ago now. I know I dont have a grease gun for the zerk's...
Off looking for the FSM now, and thanx again
94 montero SR 3.5. 33" BFG TA KO's, OME HD rear springs, front T-bar crank.
93 600 Katana. stage 1 jet kit, Uni foam air filter
02 honda shadow. "for when the woman wants to go with"
97 Acura Integra.
Re: Quick Hello [Re: mynion] #1053372 11/05/12 10:40 PM
Chief Offline
Welcome to the forum.
Keep an eye on the 4XForum Cal-Nev section for any upcoming trips. Although it's been slow lately.
'89 Raider V6, AT, SAS'ed, Dana 44 front & rear, 5:38 gears, NP 231 T-case.
'97 Montero SR, cold weather package, 4.90 R&P, BATTLEZ suspension w/ 2" lift, JAOS grill guard & under body protection, custom rock sliders.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6103 MB (Peak: 0.6815 MB) Data Comp: Off Server Time: 2026-07-13 10:57:17 UTC
