Transfer case shifter bushing...Picture? #1053726 11/10/12 11:16 PM
motero Offline OP
Does anyone have a picture of a second gen Montero transfer case shift tower bushing. These like to crack up and fall into the t-case leaving you with almost impossible t-case shifting. I would like to see what it is supposed to look like and try to make a replacement. But having never seen one makes that difficult.
Side note; The descriptions I have found, all point out that the pin that goes through the shifter that engages the slots in the tower is off center. Mine is off center also? If they are all off center are they then supposed to be off center?
Thanks
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Transfer case shifter bushing...Picture? [Re: motero] #1053727 11/11/12 02:36 AM
motero Offline OP
The pin is not supposed to be off center. I made a longer pin so even with out the bushing to center the shaft it will stay in place and shift properly.
01 montero limited
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5876 MB (Peak: 0.6357 MB) Data Comp: Off Server Time: 2026-10-22 07:40:16 UTC
