Got a question about a 1990 LWB Montero rear axle.
#1053803
11/12/12 02:00 AM
I've searched and I haven't found anything. I'm new to monteros but not to offroading. My first question is I have a 1990 Montero LWB with coil springs and was wondering what rearend is in it and is it strong. My axle seals are leaking and was wondering if I should fix or try to find a Gen 2 SR. Im not going to be hard core offroading with this vehicle.
1990 LWB 3.0 Auto Tan interior Mostly Stock 194k
Re: Got a question
[Re: Devilmontero]
#1053804
11/12/12 02:05 AM
Welcome to your first post.
There is nothing wrong with the Gen I rear axle, you already own it. The seal is not too difficult to replace and is much less work than swapping in a Gen II axle. I won't go into the Gen II axle topic too much, because there are numerous threads documenting them. The benefits are a wider track, disc brakes and an air-locker (not like ARB).
I'd just replace the seal and wheel bearing, turn the drums, adjust your brakes and be done the same day.
Russell
Re: Got a question
[Re: rxinhed]
#1053805
11/12/12 02:09 AM
Gen 1 v6 axle and ring gear are plenty strong and with a more powerful engine, the gen 2 SR is even bigger/stronger design. For the stock pose plant, the gen 1 rear drivetrain is plenty strong enough. Be sure to upgrade the trailing arms though.
Re: Got a question
[Re: off-roader]
#1053806
11/12/12 02:32 AM
Thanks guys. One more question. Can you tell me what the rearend is. It looks like a ford 9" but I know it's not.
Re: Got a question
[Re: Devilmontero]
#1053807
11/12/12 02:44 AM
Thanks guys. One more question. Can you tell me what the rearend is. It looks like a ford 9" but I know it's not. Nope it's not. From what we've been able to learn in over a decade of research is they're a Mitsubishi Gearset. No other vehicles use them. That said IIRC the Gen 1 v6 is at least ~8.5" ring gear while the 3.5l Montero's a have a 9.5" ring gear. HTH
Re: Got a question
[Re: Devilmontero]
#1053808
11/12/12 02:47 AM
it's a 9" MMC or KOYO , I'm not real sure on what plant the axle is built in, all I know is you can't break it or wear it out. Many came with LSD . Look for orange sticker in drivers door jam. The LSDs last forever, too. Ratio is 4.625,,,that info and more is on a tag near radiator.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
Re: Got a question
[Re: off-roader]
#1053809
11/12/12 03:25 AM
I really appreciate it. Guess I'll be ordering some axles seals next week
Re: Got a question
[Re: Devilmontero]
#1053810
11/12/12 03:29 AM
Welcome to The Wire. Read the posting guidelines thread. My answer to your subject would be "Got an answer..." Seriously though, you want people to read your thread. A bad topic doesn't help your pursuit.
