Anyone replace the Crankshaft? #1053833 11/13/12 12:10 AM
Drewz Offline OP
Hey Everyone!
I need some help, A few months ago The front cam shaft bolt sheared off my Monty. I parked it and a friend offered to use his puller/come along to remove the sheared off piece from the Crank, well he snapped it off and now it appears I need to replace the Crankshaft completely since I now have a hardened piece of steel broken off into it.
Has anyone ever replace the crank? any idea of where I might purchase one with all the bearings etc? Anywhere I can get the details/step by step on this? I had the Shop Manuel for my Monty but since I loaned it out to a friend a few years back he doesn't remember if he returned it or not.(convenient story I know)
Any help would be appreciated. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Also is it possible to jack up the rig and do this repair from the bottom?
Thanks for any help!
Drew
91 Monty RS stock sitting on 31's w/polished Alum 16"s 265,000 orig.
Re: Anyone replace the Crankshaft? [Re: Drewz] #1053834 11/13/12 12:26 AM
Download the FSM per the FAQ post for a start. There may be a post where someone discusses the process but you'll need to check on the FAQ post or do a search on the forum.
Re: Anyone replace the Crankshaft? [Re: off-roader] #1053835 11/13/12 01:00 AM
justice Offline
Re: Anyone replace the Crankshaft? [Re: justice] #1053836 11/13/12 02:37 AM
Drewz Offline OP
This thread seems to be about the bolt. My friends puller broke off while trying to remover the sheared bolt.So now it seems my only course of action is to replace the entire crankshaft. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Anyone replace the Crankshaft? [Re: Drewz] #1053837 11/13/12 03:10 AM
I have a long block that could cheaply donate a crank to your project, not too far away either.
Russell
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6083 MB (Peak: 0.6735 MB) Data Comp: Off Server Time: 2026-05-29 23:56:41 UTC
