DIFF DROP KIT #1055020 12/13/12 10:31 AM
4
4runnernomore Offline OP
Hi everyone.
Well it is finally here. A real diff drop kit to suit our Sportages. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
The diff drop kit is suitable for 3-4 inch lift kits.
A big thank you to RUNT 313 ( cheers Chris <img src="/forums/images/graemlins/cheers.gif" alt="" />) and Shaun from GSE4x4.com in Australia.
I have mine on order and hope to have it posted up next week.
Here is a picture of the diff drop kit.
Cheers, Chris <img src="/forums/images/graemlins/cheers.gif" alt="" />
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
Re: DIFF DROP KIT [Re: 4runnernomore] #1055021 12/14/12 01:43 PM
TheGoat Offline
cost?
So, i bought an 01 Kia Sportage. before i even drove it, i nick-named it The Goat.. it has been just like a goat.. stubbern at every corner...
Re: DIFF DROP KIT [Re: 4runnernomore] #1055022 12/15/12 08:16 AM
Peabody Offline
You've got my attention! Looking forward to seeing some pics of the install and feedback on how it performs. I second Goat's question... Cost?
Re: DIFF DROP KIT [Re: Peabody] #1055023 12/15/12 12:06 PM
4
Guys,
It was $180 with postage from Melbourne to Darwin in Australia.
I am guessing around $10-15 postage with the weight so the actual kit probably $160-$170
Fo firmer prices including postage to America I suggest you contact Shaun direct at GSE 4x4.com.
Cheers, Chris.
Re: DIFF DROP KIT [Re: 4runnernomore] #1055024 12/15/12 08:49 PM
TeamCatFlap Offline
Looks good.
But I'm curious of one thing.
The long bolt and spacer and one of the shackle like parts I know would be to drop the right side of the diff assembly (Right side when sitting in the vehicle).
But how does the second shackle part drop the left side?
when I looked at mine it is hanging off of a mounting perch on the frame. Can take the bolt right out and it will just hang there. i would almost think another long bolt with a spacer would be the ticket there to relocate it under the perch (Might not even need a spacer.....)
But I've not torn it all apart fully for any reason, so I may be missing something. <img src="/forums/images/graemlins/wink.gif" alt="" />
(I tried dropping the diff on the left side to get my lift in like i did on the right, but could not by just removing the bolt so I pulled the CV axle instead to make install room.)
2001 Kia Sportage
Warn manual hubs, 2" spacer up front, TJ 105 springs Rav4 shocks, 235/75/15 BFG A/T KOs, Skidplate back to under the T-case, trans cooler, XRC8 winch on custom bumper, Synth winch line, fuel can mount, Rigid D2 Dually overhead lights.
Re: DIFF DROP KIT [Re: TeamCatFlap] #1055025 12/16/12 02:11 PM
Runt313 Offline
Hey all ive had no problems with my kit cv's are much happier and she has been out for beating so diffentaly worth it smile
Re: DIFF DROP KIT [Re: 4runnernomore] #1055026 12/22/12 02:02 AM
DennisThompson Offline
Looks good, send a few pics installed when possible.
Dennis
Re: DIFF DROP KIT [Re: DennisThompson] #1055027 03/28/13 05:29 AM
Everet Offline
Just wondering if anyone is able to post some pictures of the dropped front axle install? How much drop does the kit have?
Sounds like it is easy to install.
<img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: DIFF DROP KIT [Re: Everet] #1055028 03/29/13 04:41 AM
4
Will do,
waiting on my new front end parts (balljoints, tie rod ends etc) to come up from down South. should have been in Darwin yesterday unfortunately they did not arrive. Should be here early next week. Hopefully will have pictures by next weekend. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Happy Easter everyone and be safe if you are on the road.
Re: DIFF DROP KIT [Re: 4runnernomore] #1055029 10/16/13 05:41 AM
Davey Offline
Chris, is the diff able to move around a bit (front to rear) using the extension shackles?
Looking at this option to solve my CV/strut problem
Long a$$ 2000 Sporty, auto, 5.38 gears, TF front locker, 4"+ front lift (Kings +40 springs, 50mm spacers, 1.5" diff drop), TJ 104 rears 3" + 50mm coil spacers, 1.5" body lift, 31/10.5r15's on 15x8 Kings (ET-13), WARN manuals, Smart Bar, spotties
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6416 MB (Peak: 0.7661 MB) Data Comp: Off Server Time: 2026-10-22 07:40:00 UTC
