1988 6.2 diesel suburban #1055068 12/14/12 03:43 PM
METALMOVER Offline OP
Just purchased a 1988 diesel military suburban, glow plugs don't always want to come on when I turn the key on.Where should I start. METALMOVER
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
Re: 1988 6.2 diesel suburban [Re: METALMOVER] #1055069 12/14/12 07:43 PM
4x4Wire Offline
First, make sure you are receiving the correct voltage at the glow plug and work back towards the ignition system if you are not.
In addition to glow plug, there could be a pre-lub pump that is in the circuit.
But, intermittent operation and the fact that it is former military vehicle, I would pay close attention to the ignition switch, wiring and connector plugs.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: 1988 6.2 diesel suburban [Re: 4x4Wire] #1055070 12/19/12 03:31 AM
The glow plug controller gave my 1-ton Chevy problems. My favorite way to deal with that was to remove the GP controller and install a set of the auto-temp sensing Delco glow plugs and a switch. There are several write ups online that discuss the procedure.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5944 MB (Peak: 0.6476 MB) Data Comp: Off Server Time: 2026-06-17 13:15:54 UTC
