1990 Montero Shift Lever #1055307 12/19/12 04:02 AM
Stoicwatchman Offline OP
Ok, so I've broken the only thing I never considered breaking, and am now in need of a replacement. I have a 1990 Montero, 3.0 V6, with a 5speed manual transmission, and I've broken the gear shift lever. I have not been able to nail down an appropriate "word" to define the part, so in layman's terms...it's the lever with 1-5 & R on it, to select the gear you want. Easy right? Now find it on a parts website....HELP!!
I should note I believe it to be a V5MT1-1 (or -2) model...I'm not sure how to tell them apart...
--1990 Montero, 3.0L V6, 5sp Manual--
Re: 1990 Montero Shift Lever [Re: Stoicwatchman] #1055308 12/31/12 06:04 AM
Marty_Emery Offline
is it the shift gate itself or just the knob? i may have one, is the casing cracked and the lever flops around> might be internal trans if problem or may just have become disconnected. is it a crawler? my buddy damaged his also everything under chassis by landing the monty on a rock and high centering it
daddy got new shoes from the wife, cant wait to pull that montero up on the hood of ur car at the local grocery store and give u a perm autograph, jk
Re: 1990 Montero Shift Lever [Re: Marty_Emery] #1055309 12/31/12 06:53 AM
It's the entire control lever. From the ball to the bearing where it enters the top of the transmission. I have effectively broken the gear shift lever in half...
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5915 MB (Peak: 0.6450 MB) Data Comp: Off Server Time: 2026-10-22 02:20:18 UTC
