knuckle arm? #1055355 12/21/12 04:39 AM
O
oldsub86 Offline OP
My son was out running around in the snow tonight and managed to bang the old 4Runner into a curb pretty hard. Now the alignment is way off. You can see that the left front wheel is turned outward.
Had a quick look under with a light. It is dark and a bit cold here right now. Looks like he bent the knuckle arm that the outer tie rod attaches to.
Looking online at parts diagrams, it looks like that is a piece that just bolts onto the knuckle and therefore should not be all that much of an issue to swap out.
Am I right about it just being a bolt on part?
Randy
1995 V6 SR5 5 speed 4X4 - 4Runner - dark blue
Re: knuckle arm? [Re: oldsub86] #1055356 12/21/12 07:14 AM
4Crawler Offline
It does appear to be a bolt-on part according to a Factory Service Manual diagram.
Re: knuckle arm? [Re: 4Crawler] #1055357 12/21/12 03:13 PM
Staceman Offline
I had the entire assembly for each side, up until 2 weeks ago. I had the pleasure to disassemble everything. Yes, it bolts together, and those bolts are really, really, really, really, REALLY tight... Just letting you know. Your best bet may be a junk yard on this one. Good luck!
Re: knuckle arm? [Re: Staceman] #1055358 12/21/12 04:34 PM
G
Greg_Canada Offline
Yep, 2 bolts and they come off. I had to use a giant breaker bar... impact wouldn't do them... they are covered in red loc-tite... make sure to re loc-tite on installation!!!
89 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6034 MB (Peak: 0.6593 MB) Data Comp: Off Server Time: 2026-10-22 12:15:33 UTC
