Triton ML Gearbox removal #1055533 12/28/12 09:53 AM
BAZINGA Offline OP
How on earth are you supposed to get those two bolts right at the top of the gearbox?
I can get a boomerang spanner onto them but dont have the room to work it.
What have you done to get them?
<img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Triton ML Gearbox removal [Re: BAZINGA] #1055534 12/28/12 10:14 AM
IIRC, we accesed the bolts from behind the gearbox using a Ratchet with multiple long extensions and at the end a wobble extension.
Re: Triton ML Gearbox removal [Re: BAZINGA] #1055535 12/28/12 04:06 PM
geocrasher Offline
I don't know about a Triton ML but on two transmissions I've done, a few feet of extensions and a wobble end, wrenching from behind the transmission was very productive. On my friends Ford pickup, had to unbolt the cross member and pull the trans down some in order to get at the bolts. Not fun.
http://tidbitsfortechs.com/
Re: Triton ML Gearbox removal [Re: geocrasher] #1055536 12/28/12 07:53 PM
Triton is the truck, what we call a pickup truck and I think you call a "ute"? Is it 4wd? If so, pull off the transfer case and let the tranny dangle down, and use the above method. If it's a 2wd, you may be able to let it droop down just by taking out the crossmemeber.
Re: Triton ML Gearbox removal [Re: off-roader] #1055537 12/29/12 04:50 AM
BAZINGA Offline OP
Brilliant! It worked.
I didn't even know there was a wobble extension.
99 Auto Sportage. Wildcat Extractors, Lukey Turbo Muffler, Warn manual hubs, K&N Air filter, Tyres 30/9.5/15, Ironman 40mm springs, KYB front struts & rear shocks, GME TX3220 UHF radio, dual battery system. Twin 10" electric fans. Next Job: Body lift
Re: Triton ML Gearbox removal [Re: BAZINGA] #1055538 12/29/12 05:41 AM
Yup. A good set (3", 6", & 1') is a worthwhile investment. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6123 MB (Peak: 0.6825 MB) Data Comp: Off Server Time: 2026-06-10 07:24:39 UTC
