Sad to see this go. This was actually my first vehicle that I purchased bone stock. It has since been my daily driver, and then a mild trail rig. I have owned it since 2004. Since I got married and had kids it has just sat. I moved it from Oregon>Utah and back to Oregon. It is located in Hillsboro. At this time it does not run. I got it running, passed emissions and got tags for it no problem. Then one day nothing. I am suspecting something electrical as I get nothing when I turn the key. Please note the winch in the picture is not included.
[img]
http://i.imgur.com/Fa1Og.jpg?1[/img]
[img]
[img]
http://i.imgur.com/nvx9Y.jpg?1[/img]
[img]
http://i.imgur.com/wD5SP.jpg?1[/img]
[img]
http://i.imgur.com/RCwws.jpg?1[/img]
[img]
http://i.imgur.com/PBLBj.jpg?1[/img]
[img]
http://i.imgur.com/9kE0q.jpg?1[/img]
[img]
http://i.imgur.com/dP8Hr.jpg?1[/img]
Edit: Some reason it wont take my pics... Sorry..
-1990 Isuzu Trooper II
-Blue in Color
-~215k Original Miles
-5 Speed Manual
-2.6L 4-Cyl Motor
-Warn Winch Bumper on front (Chrome. 1/4 Plate. Fairlead included). The plate is perm welded to the frame using 1/4" 2x2 steel. It has shackle points extending from the mount. However the sides of the bumper come off. Originally for a full size Chevy but I customized it. It also has quick disconnect for a winch.
-Custom roof rack. 2x50w ProComps up front and a 50w off the back. 8 mounting brackets that fit in the gutter. Made out of steel tubing.
-Custom rear bumper. Made from 1/4" steel as well. This is bulletproof. I have rolled back into trees, and even had my wife run into the corner with our Honda. $3k in damage, the bumper only had paint transfer. It has two shackle mounts and a receiver tube.
-Custom rock sliders. Made from 1/4" tubing (Seeing a trend?). Welded to the frame. Strong enough to use the HiLift in the center and lift that side of the truck.
-Interior has no carpet and has been Herculine
-MSD 6A Ignition
-Pacesetter Header
-DynoMax Muffler
-Second fuse block under hood for expansion
-XM Radio+Antenna
-Auto-Dark mirror from a Chevy truck. Compass works. I nevergot the auto dark or temp to work. Temp sensor is on truck and wired, it dosnt display correct values.
-G80 LSD installed about 2007
-Custom 1 piece driveline
-4Runner springs in the rear w/ custom greasable shackles
-Torsion bars cranked in the front
-Pioneer 6x9 speakers in the rear and Pioneer HU
-31" Tires. Two brand new BFG Mud Terrain tires in the rear.
-Wheels are black rock crushers.
-Aisin manual hubs up front
-Full Size Spare Included. Option to mount on back door or up on rack.
I have a TON of spare parts for this rig. Spare starter, skid plate, bolts, brakes, grill, etc. I even have a York compressor or two I was going to use as on board air. These will go with the truck if the new owner decides. Hoping to get $600 for the rig.
Contact Brandon. Call/Text/Email: 503-729-9753, [email]notsosimple@gmail.com.[/email] I don't check PMs much on here so other communication is preferred.
