o-rings for jet valve plugs?
#1055749
01/04/13 10:29 PM
I have a set of jv plugs ready to install on a 2.6 Problem is that the o-rings were toast when I' pulled them from the donor engine. Do I need actual high temp o-rings (which seem to be quite hard to find around here, everyone wants to sell mass qtys at a time only). OR, can I just goop them with a good quality high temp sealant that is oil/fuel compatible?
89' v6 5-speed Raider 33's (toy) 95' LS Montero (the tow mule and workhorse) 87' 2.6 Raider (in process) 88' 2.6 Montero 2 dr (in process) 88' 2.6 Raider (organ donor) 89' 2.6 Power Ram [D50] Jr's wheels
Re: o-rings for jet valve plugs?
[Re: redsput]
#1055750
01/05/13 01:21 AM
i am not sure but i feel that maybe o rings would hate for that silicone to come loose and pack up the oil pick up
iwould at least find regular oil resistant o rings
1989 Mighty Max 4WD 2.6 Turbo,Auto EFI...megasquirt! 4.62 Rear LSD! 1989 Mighty Max 2WD 2.6 5 speed slammed 1993 Eagle Talon TSI
[Re: boostin]
#1055751
01/05/13 03:14 AM
85 Dodge D50, 90 Montero, 05 durango
[Re: cjsmontero]
#1055752
01/06/13 05:47 AM
Thanks, definitely looks like a great source! Local Fastenal guy said he's try to get me some "samples" from the distributor of an oil resistant 450 degree variant, hopefully that will pan out.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6022 MB (Peak: 0.6579 MB) Data Comp: Off Server Time: 2026-06-10 07:26:37 UTCValid HTML 5 and Valid CSS
