Gen 2.5 water pump & timing belt kits #1055833 01/08/13 02:07 PM
Randy_NC Offline OP
Has anyone used some of the kits on Rock Auto like Gates. It's time.
Re: Gen 2.5 water pump & timing belt kits [Re: Randy_NC] #1055834 01/08/13 03:33 PM
87Montero Offline
I used a Gates kit on my 2.5. It came with the Japanese Bearings (koyo I think?) Which were the same brand that came off (and still going strong at 125k miles).
I was satisfied, so I bought the Gates kit for the Hyundai when I did it -- it too came with the Japenese bearings where the OEM were Korean GMB (and exploded at 104k miles)
Re: Gen 2.5 water pump & timing belt kits [Re: Randy_NC] #1055835 01/08/13 08:44 PM
N
nckwltn Offline
I'm in the process of timing belt/water pump/head gasket job.
I believe I have a gates belt purchased as well... it came from a place where I use to order a lot of parts for my german cars. (bmaparts.com)... Be sure you replace those rollers for sure. When I pulled the right timing belt cover, the bearings from the roller on the right spewed out all over the driveway (not sure of the brand, but I'll see if I can find it.
You may also find that the timing belt cover gasket is bad... mine was flaking away was quite dry and brittle. I ordered replacements, but I may have to trim down some of the replacement to fit. The gasket for each cover is like in 4 pieces. I could only order a few of the pieces, so I ordered extra quantities of the longer pieces so I can trim them down as necessary.
Re: Gen 2.5 water pump & timing belt kits [Re: Randy_NC] #1055836 01/10/13 09:13 PM
Grandpa Offline
I'm running the Gates kit I got from Rock Auto. No problems after 2000+ miles.
2001 Montero (Her's)
2000 Montero (Mine) BFG AT KO 33-10.5R15
Re: Gen 2.5 water pump & timing belt kits [Re: Grandpa] #1055837 01/24/13 07:44 PM
Randy_NC Offline OP
The fun starts tomorrow evening. I bought the special timing belt tension tool and a adjustable cam wrench. parts listed below. Anything I'm missing. I'm planning on removing the radiator and have it cleaned also.
Gates timing belt & water pump kit
New thermostat & radiator cap
Cam seals
Front shaft seal
Valve cover gasket set
Intake gasket set
Iridium plugs
Denso plug wire set
Re: Gen 2.5 water pump & timing belt kits [Re: Randy_NC] #1055838 01/24/13 09:54 PM
TheViper Offline
Cam seals
Front shaft seal
Intake gasket set
Iridium plugs
Denso plug wire set
it would be great if you could take some pics of the work being done...sadly there hasnt been alot of pics posted on this particular job which is critical for the mitsu DOHC and SOHC motor.
1995 Montero SR
Re: Gen 2.5 water pump & timing belt kits [Re: Randy_NC] #1055839 01/24/13 11:15 PM
N
nckwltn Offline
be sure you have 22mm socket so you can get the crank shaft pulley off. Also, you'll need something to hold onto the pulley while you undo the bolt. I ended up using a chain wrench, and it worked like a champ.
Re: Gen 2.5 water pump & timing belt kits [Re: nckwltn] #1055840 01/24/13 11:50 PM
Randy_NC Offline OP
Hopefully this is going to work. I will try and keep my progress posted and pictures.
[img][image]http://i746.photobucket.com/albums/xx101/IRollS40/th_P1020912_zps43ebff7d.jpg[/img][/image]
Re: Gen 2.5 water pump & timing belt kits [Re: Randy_NC] #1055841 01/25/13 01:08 AM
N
nckwltn Offline
is that the exact tool called for in the FSM? it looks like it should work.. but the bolt is going to be on there pretty tight... so you might want a length of pipe to place over the handle of that tool so you can get more mechanical advantage.
might not hurt to replace the spark plug tube gaskets too. If you haven't done the job before, have fun with the AC pump thing (on the drivers side). It's held to its bracket by 4 12mm bolts (one at each corner), then the bracket itself needs to come off. 5, 14mm bolts if I remember correctly.
Removing the radiator will be a big help to getting you more room. I just did my timing belt & water pump... but my replacement water pump wasn't EXACTLY the same size as my original. So it took a little filing to make sure that everything was in spec before the accessory mount would line up properly.
Re: Gen 2.5 water pump & timing belt kits [Re: nckwltn] #1055842 01/25/13 01:35 AM
Randy_NC Offline OP
Thanks for the heads up. I do have a copper pipe I slip over my 1/2 inch socket to get more leverage. I have been reading manuals and watch every youtube video I could find. Knowing how and doing are two very different things sometimes.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6386 MB (Peak: 0.7639 MB) Data Comp: Off Server Time: 2026-06-23 11:15:30 UTC
