cracked air plenum 95 SR #1055896 01/10/13 05:07 PM
chelo Offline OP
Poking around my engine trying to find the source of a dead spot at idle and running rich, I discovered some cracks (more like holes) on my upper air plenum. I've never seen cracks so big on a plenum (pic attached), what could have caused this? Also, I would have expected my engine running much worst and having the engine light on. It even passed emissions with flying colors, and I know I had the engine miss when I did emissions so I think the cracks were already there.
Dealer wants $940 for it (part only). Can you guys recommend a good national junkyard that I can source the part from? Thank you much!!
Re: cracked air plenum 95 SR [Re: chelo] #1055897 01/10/13 08:34 PM
Hi Chelo & welcome to 4x4wire's Mitsu forums.
It's not common for them to crack that I can recall however it is common for the internal butterfly valve to fail and I wonder if it could have been ingested into the engine intake and then somehow spit back out? Not sure but I am confident others will chime in to try and help diagnose what happened.
As for as a used one, try car-part.com for a network of salvage yards where you can likely find a donor part. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: cracked air plenum 95 SR [Re: off-roader] #1055898 01/10/13 11:26 PM
mxmikie Offline
i have a good center section with the butterflys removed and pluged
Re: cracked air plenum 95 SR [Re: chelo] #1055899 01/11/13 12:08 AM
TheViper Offline
i dont see the pic attached anywhere, i would really like to see it.
EDIT:@mxmike...just out of curiosity, how much would you let that plenum piece go for?
1995 Montero SR
Re: cracked air plenum 95 SR [Re: TheViper] #1055900 01/11/13 01:09 AM
I'd try JBWeld....
Re: cracked air plenum 95 SR [Re: fasteddy] #1055901 01/11/13 01:34 AM
ryany Offline
If you add your location to your profile, you might get some local wrecking yard recommendations from forum members in your area.
95 Montero SR
Re: cracked air plenum 95 SR [Re: TheViper] #1055902 01/11/13 01:53 AM
mxmikie Offline
35.00 plus ship
Re: cracked air plenum 95 SR [Re: mxmikie] #1055903 01/11/13 02:06 AM
TheViper Offline
35.00 plus ship
i might just pick it up (passing through on my way to NY), ive never messed with my butterflys, im not sure if that plenum piece was ever updated with the correct piece...
sorry to the OP for high jacking his thread <img src="/forums/images/graemlins/frown.gif" alt="" />
1995 Montero SR
Re: cracked air plenum 95 SR [Re: TheViper] #1055904 01/11/13 06:18 AM
mxmikie Offline
hahahahaha cool here is a map to the new place i will leave a light on for ya ........ https://maps.google.com/?ll=33.80348%2C-113.92031&z=17&t=h
Re: cracked air plenum 95 SR [Re: mxmikie] #1055905 01/11/13 10:48 PM
chelo Offline OP
well, looking at it from the inside with one of those dentist mirrors I guess it is factory. It just looked strange when looking from the outside because of the raw edges, but I guess it was just the casting. So my dead spot is not a crack on the plenum, will have to keep looking for the source of the problem..
Thanks for the replies.
Marcelo
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6405 MB (Peak: 0.7654 MB) Data Comp: Off Server Time: 2026-06-10 07:24:55 UTC
