Anybody have nice Diagram or photos of Washer hoses in 95 SR? #1056283 01/22/13 04:00 PM
sasnydley Offline OP
Since I have had this truck roughly 2 years I have not had or needed washers (Florida)... But in Feb. I may be taking a road trip North to bring my step-dads boat back south. The motor will kick on-just no hoses are around. When I got this truck it had some obvious motor work. The AC had been wired wrong and I am guessing the washer hoses removed and never replaced...
Re: Anybody have nice Diagram or photos of Washer hoses in 95 SR? [Re: sasnydley] #1056284 01/22/13 07:12 PM
P 51-13 in the fsm on mitsubishilinks.com. A later page shows the headlight washer hose routing.
I looks pretty simple. The hose runs from the tank thru a inner fender grommet to the hose on the underside of the hood, which tees to the two sprayers on the hood.
Re: Anybody have nice Diagram or photos of Washer hoses in 95 SR? [Re: fasteddy] #1056285 01/23/13 01:43 AM
I am dreading having to go into the fender... I have a funny feeling the hose is buried in it some where.
Re: Anybody have nice Diagram or photos of Washer hoses in 95 SR? [Re: sasnydley] #1056286 01/23/13 03:33 AM
W
willwinchforfood Offline
Just buy a snorkel. You have to cut a hole big enough to get your hand in the fender for that. Or just cut the hole and tell everybody you are going to put a snorkel on there someday.
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: Anybody have nice Diagram or photos of Washer hoses in 95 SR? [Re: willwinchforfood] #1056287 01/23/13 04:06 AM
Pull the inner fender liner to get at it. Dside...
Re: Anybody have nice Diagram or photos of Washer hoses in 95 SR? [Re: fasteddy] #1056288 01/23/13 10:32 PM
LOL Snorkel would be opposite side of truck! That would not be good. Fake snorkel... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Anybody have nice Diagram or photos of Washer hoses in 95 SR? [Re: sasnydley] #1056289 01/23/13 11:00 PM
jdavis Offline
I pulled the fender off my '94 to replace the antennae and found the hose was no longer attached to the reservoir.
Guessing there was originally a piece that attached to the hose to reservoir but it's missing.
Could not see any easy way to reattached hose so did not mess with it.
Have to replace the antennae again, keep tearing it off on the trail. Maybe I'll look at reattaching.
~ Jon
95 Montero SR
33 x 12.50
Aussie Locker
OME Heavy Duty Coils & Torsion Bars
ARB Front Bumper
76" Trail Gear Rock Sliders
XRC-9.5K Winch
Re: Anybody have nice Diagram or photos of Washer hoses in 95 SR? [Re: jdavis] #1056290 01/23/13 11:44 PM
Crops Offline
Getting at that antenna? Difficult? What are the steps? Anything tricky to watch out for?
89 Raider V6
95 SR Montero
Re: Anybody have nice Diagram or photos of Washer hoses in 95 SR? [Re: Crops] #1056291 01/23/13 11:49 PM
My understanding... remove the plastic fender liner and you have direct access to the antenna assembly however you'll also need to disconnect it from the radio and feed the antenna wire up and out through the hole in the firewall.
Grasscat may have more insight as he's done it before with his. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Anybody have nice Diagram or photos of Washer hoses in 95 SR? [Re: off-roader] #1056292 01/23/13 11:59 PM
Yes, do it that way, but fasten a snake wire to the antenna cable as you pull it out so you can pull the new one back in, or you'll end up having to take out a lot of stuff to get it back in.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6423 MB (Peak: 0.7649 MB) Data Comp: Off Server Time: 2026-05-29 17:26:41 UTC
