Power Antenna 95 SR #1056400 01/28/13 06:39 AM
hochkis Offline OP
So the power antenna on my 95 SR is broken internally, And whenever the radio turns on it makes a terrible noise. Is there a fuse I can pull that would disable the antenna and not the radio?
And while I'm on that note does anyone have a picture of the interior fuse box diagram?
95 Montero SR- Stock
90 Turbo Miata - TD04 wrx turbo, Flyin miata suspension, Torsen diff, 225 RS3's
92 Mighty Max 4x4 - Retired
Re: Power Antenna 95 SR [Re: hochkis] #1056401 02/02/13 06:54 AM
motero Offline
You can pull out the fender liner and just unplug the power to the antenna motor.
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Power Antenna 95 SR [Re: motero] #1056402 02/02/13 01:16 PM
Yep. about 10 screws and your in business.
Re: Power Antenna 95 SR [Re: Mudraider] #1056403 02/02/13 06:32 PM
ryany Offline
If your antenna is making noise whenever you turn your radio on or off, then the motor is fine but the plastic track that drives the antenna mast up and down is broken. You can find replacement antenna masts on ebay - http://www.ebay.com/itm/Mitsubishi-MONTE...53d&vxp=mtr - you'll have to disassemble the antenna to remove the parts of the existing plastic track that are inside the antenna, but if you're pulling the fender liner to disconnect it, you may as well pull it out and fix it while you're there.
95 Montero SR
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6018 MB (Peak: 0.6572 MB) Data Comp: Off Server Time: 2026-06-07 06:00:18 UTC
