Front differential actuator
#1056423
01/30/13 07:41 PM
How does the front differential actuator work? I'm troubleshooting my 4x4 system, as it makes crunchy noises up front when trying to engage.
The vacuum system is good, I replaced the check valve, and when I tested vacuum to the actuator it did the following:
When vacuum applied to nipple facing rear of truck, rod moved into the differential. When vacuum was removed, rod came out of the differential.
When vacuum applied to nipple facing towards the differential nothing happened.
I'm not sure if my issue is mechanical or electrical. I swapped the solenoids from my parts truck with no change.
I'll go though the wiring diagrams tonight for the electrical portion.
92 Montero SR 84 Maserati Biturbo 89 Mercedes 190E 77 Fiat X1/9
Re: Front differential actuator
[Re: m4ff3w]
#1056424
02/02/13 06:51 AM
Do you have auto, manual, or fixed hubs? How about CV joints What kind of shape are they in?
99 Montero....15mpg! Sold (so sad) 02 Jetta TDI....48mpg! 03 2500 Ram QCLB Cummins....18mpg 02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold) 01 montero limited
[Re: m4ff3w]
#1056425
02/02/13 02:01 PM
The actuator is engaged/disengaged with vacuum only. The yellow vac hose with vacuum shifts to 2H and the blue vac hose with vacuum shifts to 4H. There is a sequence of operation for the solenoids (A&B). My manual has the test procedure using a vacuum pump, if you want it PM me.
[Re: motero]
#1056426
02/12/13 09:24 PM
Do you have auto, manual, or fixed hubs? How about CV joints What kind of shape are they in? They are the stock (auto?) hubs that came on the '92 SR. If I put the truck in the air, 4WD engages and disengages without making the violent crunch noises. I can turn the wheel about 10* before the front drive shaft starts to turn, this is on both sides.
[Re: pcc]
#1056427
02/12/13 09:26 PM
I see the actuator move, so I've isolated that it isn't my issue. I'm unsure of where to go from here though.
[Re: m4ff3w]
#1056428
02/12/13 11:53 PM
Put all 4 wheels in the air. Shift into 4wdlo. Hand rotate the front driveshaft and feel the front hubs lock up and feel for graunchy stuff as they do. You may have a bad hub lock. Also possible you have a bad front diff, badd cv joint, bad bearings, or bad transfer case, and hand rotation may reveal such.
[Re: fasteddy]
#1056429
02/12/13 11:55 PM
Put all 4 wheels in the air. Shift into 4wdlo. Hand rotate the front driveshaft and feel the front hubs lock up and feel for graunchy stuff as they do. You may have a bad hub lock. Also possible you have a bad front diff, or bad transfer case, and hand rotation may reveal such. I believe there are no hub locks on the stock gen II. It's all centrally actuated by the CAD (Central Axle Disconnect). <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#1056430
02/13/13 05:37 AM
I did not get a chance to get it in the air tonight, but I did play with it for a bit.
I can go into 4WD Lo-Loc and 4WD Hi-Loc. But 4WD-Hi is what gives me issues.
To get to 4WD Hi-Loc I have to go into Lo-Loc first though.
