1991 Trooper Fuel issues #1056454 01/31/13 06:05 PM
Storm Trooper Offline OP
Hello!
Been a while but I'm back with some questions.
In the fall I was driving my trooper and it just died on me. When I pulled over to investigate I found that when I tried to start it no gas was being sprayed out of the injectors. I ended up having to tow it home.
When I tried to start it next it started spraying gas but it looked like FAR too much and the engine wouldn't run unless I was pressing down on the accelerator.
I tried changing the fuel filter but that didn't help.
Any thoughts?
'91 Trooper
3.4 V6, K&N, 33x12.5 Trxus MT's, Aisin hubs, 3" body lift, Rear ARB Naches Trail
Re: 1991 Trooper Fuel issues [Re: Storm Trooper] #1056455 02/01/13 12:25 AM
Jim_Paget Offline
It has been a while. Refresh us on how your rig is set up. What TBI are you running on you rig and I think I remember that you are running a 3.4. Is that right?
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: 1991 Trooper Fuel issues [Re: Jim_Paget] #1056456 02/02/13 07:41 AM
Yep. 3.4 and I have a 4.3 throttle body. Stock fuel system for the rest.
'91 Trooper
Re: 1991 Trooper Fuel issues [Re: Storm Trooper] #1056457 02/02/13 03:57 PM
Jim_Paget Offline
I would start by carefully checking all the wiring connections to the injectors. I fought similar issues for nearly a year before I went back, re-did all the connections and sealed them so that they are water tight.
Jim Paget
www.rrr4x4.com
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6006 MB (Peak: 0.6604 MB) Data Comp: Off Server Time: 2026-10-24 07:17:02 UTC
