No spark coil 3. 15 volts tested at jack pins ok... #1056524 02/04/13 12:32 AM
salth20 Offline OP
All you guys rock.
Here's what I got.
95 Montero SR 3.5 175,000
Coils 1 year old. New cam sensor.
Wife came home, RAN FINE. Next morning, rough idle. I disconnected thin wire set connection at coil 1 (closest to front of vehicle), very noticable change in idle, same with coil 2. I disconnected #3, no change in idle. That tells me problem is coil pack #3 or power to coil pack.
While idling, I test "female pins" (jack pins?), 2 wires from ICM; 15 volts conintuous.
Change coil with old coil from a year ago, no idea if good or not, same result.
Someone here had a similar issue and was ICM, but I have power coming from ICM to coil.
Probably coil right? I am broke and can only trouble shoot and spend enough for 1 coil. ICM's are $250.
Any thoughts????
Re: No spark coil 3. 15 volts tested at jack pins ok... [Re: salth20] #1056525 02/05/13 02:44 AM
Howah Offline
Did u test the coil ohms at primary and secondary? There's a way to test ICM as well and is describe in FSM use a 1.5v DC battery and meter.
95 Montero SR
Re: No spark coil 3. 15 volts tested at jack pins ok... [Re: Howah] #1056526 02/05/13 08:02 PM
salth20 Offline OP
I tested it with my meter which is a construction type. It read .09 ohms at the pins.
I don't get any reading between the coil "head" and the spark plug side. That tells me that it has no connectivity???
It would be nice to know how these coils work.
Re: No spark coil 3. 15 volts tested at jack pins ok... [Re: salth20] #1056527 02/05/13 08:31 PM
Howah Offline
95 Montero SR
Re: No spark coil 3. 15 volts tested at jack pins ok... [Re: Howah] #1056528 02/06/13 12:59 AM
salth20 Offline OP
I found that page. Thanks:)
So if there was no reading on secondary test, wouldn't you say it was bad coil?
Re: No spark coil 3. 15 volts tested at jack pins ok... [Re: salth20] #1056529 02/06/13 02:06 AM
W
willwinchforfood Offline
Move the suspect bad coil to another position and put a known good coil in the suspect spot. Say swap two and three. Do it. Go do it now.
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6075 MB (Peak: 0.6772 MB) Data Comp: Off Server Time: 2026-06-07 05:58:07 UTC
