Gen II Body Lift #1056656 02/08/13 07:31 AM
jdavis Offline OP
Contemplating installing one of 4crawler lift kits from the reading I've done it sounds like a relatively straight forward install.
But curious what needs to be extended when the kit is installed - brake lines, fuel filler hose, wiring, etc.... ?
Thanks for any insights.
~ Jon
95 Montero SR
33 x 12.50
Aussie Locker
OME Heavy Duty Coils & Torsion Bars
ARB Front Bumper
76" Trail Gear Rock Sliders
XRC-9.5K Winch
Re: Gen II Body Lift [Re: jdavis] #1056657 02/08/13 05:42 PM
Nothing needs to be extended but the brake lines do need to be 'adjusted' at certain points.
Have you checked the FAQ post for a thread on the procedure?
Re: Gen II Body Lift [Re: off-roader] #1056658 02/08/13 06:00 PM
jdavis Offline OP
Did check the FAQ and read a couple of articles on the expedition portal but still find it hard to believe nothing needs to be extended <img src="/forums/images/graemlins/scared.gif" alt="" />.
I know you've had yours lifted for quiet some time. So, I'll take your word for it.
thanks,
~ Jon
95 Montero SR
33 x 12.50
Aussie Locker
ARB Front Bumper
XRC-9.5K Winch
Re: Gen II Body Lift [Re: jdavis] #1056659 02/08/13 06:29 PM
Canyonero Offline
Only thing I had to do was tweak the brake lines coming through the front fender wells and crank the torsion bars a bit to help with tire clearance. On the 'to do' list is to notch out part of the center console where the 4x4 shifter comes through to gain a little clearance. The bend in the shifter interferes a bit after the body lift. Took me about 1.5 hours start to finish by myself to do the lift. There is a brace in the middle of the truck underneath that I used a floor jack and some scrap wood to lift each side of the truck to install the lift blocks.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: Gen II Body Lift [Re: jdavis] #1056660 02/08/13 06:30 PM
ryany Offline
I had no issues when I installed mine - I only had to adjust the front hard brake lines where they pass through the front aprons,
95 Montero SR
Re: Gen II Body Lift [Re: ryany] #1056661 02/08/13 06:44 PM
Same thing Ryan said. No extra cutting was required.
Re: Gen II Body Lift [Re: jdavis] #1056662 03/16/13 01:24 AM
jdavis Offline OP
Wahoooo!!! The 4 Crawler 2 inch body lift kit arrived today!
95 Montero SR
33 x 12.50
Aussie Locker
ARB Front Bumper
XRC-9.5K Winch
Re: Gen II Body Lift [Re: jdavis] #1056663 03/16/13 01:29 AM
socalmonty Offline
Nice! smile
The install isn't bad at all. Just a bit time consuming. Take your time, have a beer and in a couple hours she'll be all set. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sean - Orange County, CA
MAIL: seanwilliams78@gmail.com
1995 Montero SR - For exploring and getting away!
1994 Volvo 850 Turbo - 402hp and counting!
1966 VW Bug 2275cc - For stoplight drags!
Re: Gen II Body Lift [Re: socalmonty] #1056664 03/16/13 02:55 AM
jdavis Offline OP
Nice! smile
Thanks Sean!
Plan on setting aside a weekend to do the lift.
Anyone have any tips or tricks for jacking up the truck body?
Thanks ,
Jon
95 Montero SR
33 x 12.50
Aussie Locker
ARB Front Bumper
XRC-9.5K Winch
Re: Gen II Body Lift [Re: jdavis] #1056665 03/16/13 06:03 AM
E
eurosonic Offline
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6398 MB (Peak: 0.7649 MB) Data Comp: Off Server Time: 2026-07-15 02:06:31 UTC
