90 3litre to 88 3litre engine swap *DELETED* #1057051 02/18/13 02:27 AM
METALMOVER Offline OP
Post deleted by METALMOVER
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
Re: 90 3litre to 88 3litre engine swap [Re: METALMOVER] #1057052 02/18/13 02:52 AM
I believe that the '88' Raider would have the 2.6l. You signature says '89' Raider. If the latter is correct, then the 90 engine will be the same. The drivers side exhaust manifold, distributor and some other pieces are different.
Also, if you can get a Montero for 2 bucks, go for it.
PHP: 7.4.33 Page Time: 0.022s Queries: 15 (0.019s) Memory: 0.5863 MB (Peak: 0.6348 MB) Data Comp: Off Server Time: 2026-07-14 07:25:59 UTC
