Oil in Spark Plug Well #1057070 02/18/13 07:43 PM
KWitcher Offline OP
I am replacing my plugs and found that one of those deep spark plug wells is full of oil. When I pulled the plug it looked normal and dry on the inside. Any thoughts as to where the oil came from?
95 Montero SR
Re: Oil in Spark Plug Well [Re: KWitcher] #1057071 02/18/13 10:51 PM
lordtrunks Offline
valve cover is leaking
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Oil in Spark Plug Well [Re: KWitcher] #1057072 02/19/13 04:30 AM
N
nckwltn Offline
yeah.. I agree.. those top valve cover seals around the spark plug tubes are leaking..
20-30 from rock auto for a set... just replaced mine.
Re: Oil in Spark Plug Well [Re: lordtrunks] #1057073 02/19/13 02:58 PM
KWitcher Offline OP
OK. Thanks for the response. I guess I need to pull those covers now.
95 Montero SR
Re: Oil in Spark Plug Well [Re: KWitcher] #1057074 02/20/13 04:03 AM
Felpor has a full kit for the 3.5 SOHCs that is the VC gaskets and the plug tube grommets.
And while you're doing all that, might as well fo the valve guide seals, and all the o-rings and grommets on the fuels rails / injectors.
And while your at that, change all the water line hoses and o-rings.
And of course new plugs and wires...
Re: Oil in Spark Plug Well [Re: MontyMcV] #1057075 02/21/13 05:12 AM
KWitcher Offline OP
You may have a point on the valve seals. After trying about 5 different seal conditioners I found one that worked (no more smoke). But if I have to pull the valve covers, I guess I am pretty close to the valve seals.
95 Montero SR
Re: Oil in Spark Plug Well [Re: KWitcher] #1057076 02/21/13 02:50 PM
TheViper Offline
Sure would be great if you could share that magical conditioner that worked, as i think alot of people have the smoke issue from leaky valve seals, and for me I simply dont have the mechanical nohow to do valve seals <img src="/forums/images/graemlins/frown.gif" alt="" />
1995 Montero SR
Re: Oil in Spark Plug Well [Re: TheViper] #1057077 11/06/14 07:26 PM
KWitcher Offline OP
I know that this is a really old post, but the stuff I use is Bardahl No-Smoke + Stop Leak. I get it a Walmart and I use 10w40. This combo has no smoke. I have tried 4 or 5 others and none worked until I tried this one.
95 Montero SR
Re: Oil in Spark Plug Well [Re: KWitcher] #1057078 11/06/14 10:30 PM
Thanks for posting that. Do you recall the price? Just wondering since it's available online for ~$12 and with amazon prime, I can get it in just 2 days.
Re: Oil in Spark Plug Well [Re: off-roader] #1057079 11/07/14 07:36 PM
KWitcher Offline OP
Less than $5.
95 Montero SR
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6289 MB (Peak: 0.7202 MB) Data Comp: Off Server Time: 2026-07-14 09:35:48 UTC
