Nephews 89 3.0 having hard time going into gear? FIXED! #1057156 02/20/13 11:52 PM
sasnydley Offline OP
His 89 3.0 5sp 2 door is having hard time getting into gear. I am going to swap out the clutch master and slave.
Will this fix it or is it a sign of things to come?
He is planing on fixing it and selling it.
Re: Nephews 89 3.0 having hard time going into gear? [Re: sasnydley] #1057157 02/21/13 06:51 AM
Tried bleeding the clutch?
mine did that, then bled the clutch, getting new fluid in system and it's fine!
Re: Nephews 89 3.0 having hard time going into gear? [Re: Mudraider] #1057158 02/21/13 02:14 PM
bearingman Offline
Not to hijack thread, but has he had any issues with the clutch pedal not coming back up all the way? Mine stays about half way down.
Re: Nephews 89 3.0 having hard time going into gear? [Re: Mudraider] #1057159 02/22/13 11:42 PM
going to try that first.
Re: Nephews 89 3.0 having hard time going into gear? [Re: sasnydley] #1057160 03/19/13 06:55 PM
RaiderGriz Offline
I having the same issue, mostly in AM when it's cold. Mudraider is there a walkthrough on that process I can search and find? Also bearingman; I have that issue also, what did you do to resolve it? Thanks Gentlemen! smile
You maybe younger and can run faster, but I am older and have been around long enough to know where all the shortcuts are!
1989 MTs/Dodge Raider SWB V6 5spd - Daily Driver/Work in Progress.....
Re: Nephews 89 3.0 having hard time going into gear? [Re: RaiderGriz] #1057161 03/19/13 09:22 PM
RaiderGriz Offline
What I have found so far:
Bleeding Clutch found here:
[url=http://www.4x4wire.com/forums/showflat.php?Cat=0&Number=896989&an=&page=0&vc=1][/url]
Re: Nephews 89 3.0 having hard time going into gear? [Re: RaiderGriz] #1057162 03/20/13 01:19 AM
Swapped the Clutch master and slave. Bled the system. Works better than ever.
Re: Nephews 89 3.0 having hard time going into gear? [Re: sasnydley] #1057163 03/30/13 07:12 AM
RaiderGriz Offline
Which brand you go with?
Re: Nephews 89 3.0 having hard time going into gear? [Re: RaiderGriz] #1057164 03/31/13 02:46 AM
Brand? Came from Autozone. Was made in Tiawan I think LOL. Each piece was like $24.00.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6221 MB (Peak: 0.7085 MB) Data Comp: Off Server Time: 2026-07-14 10:50:20 UTC
