driveshaft flange bolts #1057442 03/04/13 08:34 AM
StockRaider Offline OP
Never got any reply from the Parts wanted section.
Long story short, I am missing 4 nuts bolts and lock washers for the driveshaft on my SR axle, they are bigger than the 89, so I need them BADLY. Anyone have some extra laying around? ASA doesn't list them <img src="/forums/images/graemlins/shiner.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: driveshaft flange bolts [Re: StockRaider] #1057443 03/04/13 11:06 PM
Sorry, I'd send you the bolts but I don't have any.
Are you sure it's not in CAPS/Mitsu ASA? I'm getting part numbers when I look it up. I used VIN JA4MR51M7SJ008996 which is from an SR Montero built in 94 (Prod Period 1994091-1994091).
Bolt: MB505065
Washer: MB450406
Nut: MF430122
HTH <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: driveshaft flange bolts [Re: off-roader] #1057444 03/04/13 11:54 PM
I am concerned that might be the bolt for the front driveshaft, or does the SR have the same sized front and rear? ASA marks the driveshaft they are showing the part on as FR front?
Richard E
1983 Honda XL600R
Re: driveshaft flange bolts [Re: StockRaider] #1057445 03/05/13 12:43 AM
Whups... just realized I was on the wrong page (4 pages) and I was giving you the front driveshaft bolts (tells you at the top of that page but I missed it).
The rear ones (for a 96 anyways) are...
Bolt: MB896988 (M12x31)
Washer: MF450407 (M12)
Nut: MF430123 (M12)
It shows the diameter is an M12 but it doesn't show the thread pitch or grade.
HTH.
Re: driveshaft flange bolts [Re: off-roader] #1057446 03/05/13 07:40 PM
socalmonty Offline
Yeah, they are easy to tell apart if you have them both in front of you. Rear are larger than the front.
Sean - Orange County, CA
MAIL: seanwilliams78@gmail.com
1995 Montero SR - For exploring and getting away!
1994 Volvo 850 Turbo - 402hp and counting!
1966 VW Bug 2275cc - For stoplight drags!
Re: driveshaft flange bolts [Re: socalmonty] #1057447 03/05/13 07:47 PM
IIRC from Mitsu ASA the fronts are M10 bolts (10mm diameter).
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6129 MB (Peak: 0.6997 MB) Data Comp: Off Server Time: 2026-07-13 11:49:51 UTC
