aftermarket cv's #1057777 03/13/13 03:09 PM
Runt313 Offline OP
Hi team,!
hope all is well, I just recieved my extended front forks and tried to fit them over the 4" lift springs and bak to that cv problem my diff drop has helped but with extended forks no good.....so i was looking into aftermarket cv's and thought maybe you guys might know where to get some! please let me know your thoughts thanks guys!
ps side bars and wheel arch bars are on and looking tough pics soon as its painted + new battery tray and first start 950 cca every 5 secs new battery! hopefully will hel; with my winch eating all my power!!
Re: aftermarket cv's [Re: Runt313] #1057778 03/13/13 03:14 PM
Runt313 Offline OP
Ps dont forget to check out the attachment
Re: aftermarket cv's [Re: Runt313] #1057779 03/13/13 03:48 PM
4
4runnernomore Offline
Hi Chris,
For everyone's research and experimentation over the years 4inch is the max you can lift your Sporty.
ny more you need to look at SASing the front end.
may I suggest you place 40-50 mm springs in the front and run the extended forks and see how that goes.
Will be finally getting my suspension fitted up next week. Can't wait.
Cheers, Chris
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
Re: aftermarket cv's *DELETED* [Re: 4runnernomore] #1057780 03/13/13 05:42 PM
Runt313 Offline OP
Post deleted by Runt313
Re: aftermarket cv's [Re: Runt313] #1057781 03/14/13 01:07 AM
Everet Offline
Chris,
I'll check around and see if I can find a source but I think we are limited. I just don't know how much with a dropped diff.
Could you send me web site and pictures of your forks. I didn't know they were still offered.
Rig is looking good!!!
Re: aftermarket cv's [Re: Everet] #1057782 03/14/13 03:51 AM
Runt313 Offline OP
everret the runtz side bars are being painted but here is the dude who hooks it up im sure he can send a photo or ill put some up next week he also does the ring and pinion to slow our gearing down! here is his details -- picorp@hanmail.net
50mm extended forks i think they cost me $133 + 85 shipping!
Re: aftermarket cv's [Re: Runt313] #1057783 03/14/13 05:36 AM
Peabody Offline
Check out this article and link to the company's website. The Sportage would definitely fall into the "custom" category...
http://www.off-roadweb.com/tech/0911or_making_cv_joints_live/viewall.html
http://www.rcvperformance.com/articulation.aspx
Re: aftermarket cv's [Re: Peabody] #1057784 03/15/13 04:30 AM
shorty_sporty Offline
Hi Chris,
The best place to try for custom drive line bits would have to be Driveline Services. They are all around Australia, so give them a call. I used to deal with the Brisbane guys heaps when I was working for Isuzu trucks, they always knew what they were talking about and pricing was reasonable.
But the most cost effective solution would be to swap the front coils over to 2 inch lift ones, those along with the forks will be plenty sufficient.
Have you considered the 5.38 crownwheel and pinion set you can get from PICORP? Also, they do an adjustable panhard rod to suit the Sportage as well.
1997 Sportage - Extended forks, Dobinsons 2 inch front lift coils, rear Dobinsons TJ lift coils, GME UHF, $8 bullbar (I love eBay!)
2001 HZJ78 Troopcarrier - 2 inch lift, extended shocks, Ex Mine vehicle. Still has yellow reflective stripe! - GONE
2011 Toyota Aurion - For the wife!
Re: aftermarket cv's [Re: shorty_sporty] #1057785 03/16/13 02:00 AM
Runt313 Offline OP
Hey PB
Look i know ur right but sorta like moving forward not settling for less!! havent found an obstacle yet we couldnt get around so just checking options! ps Track finder have a pan hard rod bracket that does the trick and $80 check it out smile thanks for ur input! can u pm me a pic ov ur beast?!
Re: aftermarket cv's [Re: Peabody] #1057786 03/16/13 11:00 AM
4
Seen the price <img src="/forums/images/graemlins/scared.gif" alt="" />Most of you would have paid less for your Sporty opposed to buying one of those CV's. 2.5 k <img src="/forums/images/graemlins/ignore.gif" alt="" /> per side.
PHP: 7.4.33 Page Time: 0.006s Queries: 18 (0.004s) Memory: 0.6382 MB (Peak: 0.7786 MB) Data Comp: Off Server Time: 2026-05-29 22:30:21 UTC
