no brakes.....sometimes #1057845 03/17/13 04:11 AM
E
experience780 Offline OP
Ive got a 00 sporty and ive got a strange problem. Every now and then when i need to come to a stop,i have no brakes!if i hit the pedal a few times (in a frenzy) it comes out of it.
Re: no brakes.....sometimes [Re: experience780] #1057846 03/17/13 04:30 AM
E
I will post pics when i can figure out how from my tablet
Re: no brakes.....sometimes [Re: experience780] #1057847 03/17/13 05:14 AM
E
Grrrrrrrrr
Re: no brakes.....sometimes [Re: experience780] #1057848 03/17/13 06:18 AM
promodmerc Offline
Does the pedal go to the floor when you experience this?
Re: no brakes.....sometimes [Re: promodmerc] #1057849 03/21/13 02:32 AM
E
Yes it does. With no pressure at all like its not even there
Re: no brakes.....sometimes [Re: experience780] #1057850 03/21/13 03:29 AM
Peabody Offline
I had a problem like that with my first car ('78 Monte Carlo). The problem turned out to be the master cylinder. Swapped it out and all was good thereafter. Might be worth looking at...
<img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: no brakes.....sometimes [Re: Peabody] #1057851 03/21/13 07:24 PM
promodmerc Offline
That is my guess as well. I had to replace mine last year. I bet if you look at it you will see where brake fluid has leaked from between the booster and master cylinder. There is a seal on the back of the master cylinder and mine went bad causing the leak.
I didn't have the brake pedal going to the floor problem. Mine is a 5 speed and I would get a hard clutch pedal because the clutch master cylinder feeds of the brake master cylinder.
Re: no brakes.....sometimes [Re: promodmerc] #1057852 03/24/13 04:17 AM
E
Hmmmmm I'll check into that. I have to replace all the brakes anyway. The last time this happened when the brakes decided to work it did so so violently the right rear shoes exploded. I'm sure they were ready to fail anyways... <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: no brakes.....sometimes [Re: experience780] #1057853 04/17/13 03:38 AM
E
An update on my brake issue, I noticed a puddle where I park the beast and when I finally got around to looking turns out you guys were right. Master cylinder is leaking between it and the booster. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: no brakes.....sometimes [Re: experience780] #1057854 04/17/13 07:12 PM
promodmerc Offline
My firewall is down to bare metal from where the brake fluid trickled down. With as slow as it leaked I just never noticed it at first. It was when I saw a small spot on my driveway that I discoverd it.
PHP: 7.4.33 Page Time: 0.009s Queries: 17 (0.005s) Memory: 0.6351 MB (Peak: 0.7583 MB) Data Comp: Off Server Time: 2026-06-07 06:08:11 UTC
