Plug wire confusion #1058009 03/23/13 02:14 AM
I
Iichart Offline OP
Ok here goes I have figured out the timing problem I had was due the metal plate behind the crank timing sprocket stripped out. So new parts are on and timing marks are all set. So far so good. Now I know the firing order is 1-2-3-4-5-6. And when I look up online the coil pack numbers it is listed as 5-2 4-1 6-3
But when I look at my coil pack bracket it is stamped this
2-5. 4-1. 6-3
So how do I hook up my wires thank you all for your help <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Plug wire confusion [Re: Iichart] #1058010 03/23/13 02:58 AM
W
willwinchforfood Offline
Mitsubishilinks.com
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: Plug wire confusion [Re: willwinchforfood] #1058011 03/23/13 03:17 AM
Canyonero Offline
Get the FSM from the link above, but if memory serves me:
#4 coil to #1 plug
#6 coil to #3 plug
#2 coil to #5 plug
And just for reference cylinder layout is like this facing engine
5 6
3 4
1 2
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: Plug wire confusion [Re: willwinchforfood] #1058012 03/23/13 03:25 AM
I
Iichart Offline OP
I did use that for my timing belt install but did not find anything about coil pack and sp wire. I did find firing order but nothing else. Or am I looking in the wrong place?
Re: Plug wire confusion [Re: Canyonero] #1058013 03/23/13 03:58 AM
I
Iichart Offline OP
I got it thank you I was not looking at the electrical part of link doooooo.
Looking at the right image does wonders. It looks like I have it right with coil packs being 2-5 4-1. 6-3.
Well lets hope for the best I will let you all know tomorrow keep fingers crossed
Re: Plug wire confusion [Re: Iichart] #1058014 03/24/13 03:22 AM
2-5 or 5-2 makes no never mind. The coil fires both plugs at the same time, on on the compression stroke and one on the exhaust stroke, which is why it's called a waste spark system. One spark is positive and one negative, but both light off the mixture just fine.
As long as the right pair of wires is on the coil, your are golden.
I've read some comments that a positive spark is somewhat more erosive of the plug electrodes, but it's either on one plug or the other, so no loss either way. Unless, of course, one of your cylinders just can't stand negative vibes.
Re: Plug wire confusion [Re: fasteddy] #1058015 03/24/13 04:38 AM
I
Iichart Offline OP
Cool thx I hope to get her up and running soon. I did notice when I looked at old plugs the anodes look very thin.
Re: Plug wire confusion [Re: Iichart] #1058016 03/27/13 04:51 PM
I
Iichart Offline OP
I would like to thank everyone for your help. My little mule is back up and running great, I am so happy I do not have to ride my motorcycle in the morning anymore. It is a very cold 50 deg this am. Brrrrrrr
Re: Plug wire confusion [Re: Iichart] #1058017 03/28/13 04:27 AM
A motorcycle in FL in the winter? Poor baby, I have no sympathy...
Re: Plug wire confusion [Re: fasteddy] #1058018 03/28/13 02:17 PM
I
Iichart Offline OP
I knew that would get someone <img src="/forums/images/graemlins/nana.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6285 MB (Peak: 0.7199 MB) Data Comp: Off Server Time: 2026-06-22 06:11:04 UTC
